Cuisinart CMW-100 Microwave Oven Logo
Anonymous Posted on Sep 22, 2012
Replaced 20amp fuse that was blown. new fuse did not blow, but oven is still dead.
Cannot see any visual electrical damage. Everything is out including the control panel.
  • Anonymous Sep 24, 2012
    After extensive searching for problem, it started working. Guess I will never know what happened.
ernesto cuadra
Level 3:
Top Expert:
  • Master 12,223 Answers
  • Posted on Sep 24, 2012
ernesto cuadra
Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4081336
Points
34431
See this causes and fix it. God bless you
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work
replaced 20amp fuse that was blown. new fuse did n - 9_24_2012_2_01_38_pm.gif
GE over the range microwave buzzing then blowing fuse
If the buzzing is like the sound of someone using an arc welding then the is a possible loose connection on the high voltage side- from the HV transformer to the magnetron.
Be very careful. The HV capacitor can give you an electric shock even when power is OFF.
Suddenly microwave stopped working
(would really like more info- digital number dead as well?)
(assuming completely dead) Could be a couple of things:
- blown fuses (inside, relatively easy to replace, std size avail at Raioshack) <-- most likely
- cut/loose power cord connection inside.
- (unlikely but worse case scenario) Door was closed crooked- one tong hit one door switch before the other- causing a short circuit internally that "self destructs" the microwave to prevent it ever operating with an open (or even crookedly ajar) door, irradiating any users. Typically it just blows the fuses, but if fuses blow immediately upon replacing and turning power on, then possibly one of the switches fused or melted internally, and needs to be replaced.
GE microwave oven model#JVM1441BH04 when you close door on switch activates and oven comes on. Only goes off when door is opened.
HELLO.
the problem your are experiencing with your microwave oven is a failed interlock switch.
Be careful when closing your microwave door. Slamming the door too hard is one of the main reasons that the interlock switch is damaged.
Slamming the microwave door shut can easily blow the microwave fuse, but they can also blow due to problems with the interlock switches.
A microwave oven will not function until the fuse is replaced.
Instruction on how to replace fuse on microwave.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
thanks.
1helpful
Fuse size for sharp mircowave r 520ks
The fuse will be a 20amp ceramic. The fuse should be available at hardware stores, Radio Shack.
If the fuse is blown, there is a very good chance you have another problem, possibly a bad or misaligned door switch, shorted capacitor. Replace the fuse, if it blows again you will have to figure out why. Door switches are the most common reason for the fuse to blow.
Is it possible to blow a fuse on a micro oven? And where would I change it?
There is a fuse found behind the upper grill, it is likely a 20amp fuse.
If the fuse has blown, it is likely that the door safety switches need to be replaced.
Change the fuse (unplug the micro first) and continue using. If the fuse blows again, have it serviced by a qualified service person.
3helpful
Yesterday, my sharp carousel r-1460 went dead. I took apart the front keypad and replaced the 20amp fuse behind it. the microwave light and fan work.But, when I start microwave to cook something, pop! fuse...
If the 20A fuse is blowing, it is often the high voltage transformer or magnetron. If this is the case, and the microwave is not under warranty, replace it. Residential microwaves are generally considered disposable. Parts and labor are just too expensive. A magntron or transformer can cost more that half the cost of a new microwave.
Unit dead Unit is dead - suspect blown fuse
The reason for this is that if you do not have any experience and training with microwaves, you can get a SEVERE shock, even if the oven is unplugged. THAT being said, if you still want to know where the fuse is get back to me. good luck.
ALSO, as you may know, a small microwave these days is under fifty bucks at walmart.
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Top Cuisinart Microwave Ovens Experts
vince
NOEL
NOEL
john h
Are you a Cuisinart Microwave Oven Expert? Answer questions, earn points and help others
