20 Most Recent
Sharp R-520KS Microwave Oven Questions & Answers
Sharp R-520KS - When the
You can tell if microwaves are being emitted if you get warm standing in front of it (seriously). But I wouldn't recommend that unless you want to cook yourself.
First thing that comes to mind is the door interlocks are out of adjustment or bad. Home microwave ovens are not supposed to operate like that. Some commercial models start the fan right away and run it after the cooking cycle is completed but I've never heard of a consumer model that does that.
Find your closest servicer
here and have them take a look.
Everything works. Time, fan, turntable, light. It
Magnetron and accompanying high voltage diode are usually to blame. Everything else works but the magnetron isn't resonating (providing the proper energy to excite your water molecules).
An appliance repairman can change it for you (typically $180) or you can get a new microwave.
I am looking for a bottom door switch for my Sharp
It should be an Omron D3V-16G-3C25, you can google that number and find a few electronic parts suppliers who sell them in a quantity of one. Likely the cheapest route is to buy off of eBay where I see them for $10 shipped.
I have a Sharp Microwave R-520 KS. And it stopped
Did you disconnect and test the three latch assembly microswitches with a multimeter or continuity tester? The top and bottom switch are normally-open, and the middle switch normally-closed. The lower switch seems to be the one that takes a beating and most often fails. It should be an Omron D3V-16G-3C25 and can be found on eBay for $10, or via an electronic parts supplier.
THE DOOR OPENER SEEMS TO HAVE A DISCONNECT AND HAS
There are three microswitches in the door latch assembly. One of them has failed (most often the lower one). With some mechanical know-how one can easily replace the bad switch with just a phillips screwdriver. There are two normally-open switches, and one normally-closed switch. They can be purchased off of ebay for about $10, and changed in 15 minutes.
Fuse size for sharp mircowave
The fuse will be a 20amp ceramic. The fuse should be available at hardware stores, Radio Shack.
If the fuse is blown, there is a very good chance you have another problem, possibly a bad or misaligned door switch, shorted capacitor. Replace the fuse, if it blows again you will have to figure out why. Door switches are the most common reason for the fuse to blow.
