LG 47LC7DF 47 in. LCD HDTV Logo
Neal Spaen Posted on Sep 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LG 47LC7DF Power surge (lightning) blew out hdmi and rgb and pc inputs, still have antenna and av inputs working. Is this an expensive fix?
Back2life Electronics
Level 3:
  • LG Master 933 Answers
  • Posted on Sep 04, 2012
LG Master
Level 3:
Answers
933
Questions
6
Helped
274660
Points
2189
You will need a new main board, your set has several different variations. The cost of the replacement board can range from $100-$150 from reliable sources. If you decide to order a new board, you will need to find out the part # of your main board so that you are ordering the correct board.
5 Related Answers
Anonymous
  • 60 Answers
  • Posted on Feb 22, 2008
SOURCE: pc to tv
Try changing the resolution on you computer. That TV may not handle the current resolution setting. You may also have to do something on your computer to turn on the rgb output.
Michael Borelli
  • 979 Answers
  • Posted on Feb 28, 2008
SOURCE: Unable to display HDMI Input
Okay so you have the HDMI cables from both the DVD and the Cable box plugged into the reveiver?
Anonymous
  • Posted on Jul 08, 2009
SOURCE: LG 32LG30 no signal when pc and tv r connected via rgb cord
For No signal try- Updating your Video drivers, and making sure it shows a connection on your laptop ( by going to propertys on desktop and then dysplay)
For format try- Updating and or turning down the screen resulotion becuase the size differs on screen even if you think it shouldnt.
dave1645
Dave Naylor
  • 834 Answers
  • Posted on Nov 28, 2009
SOURCE: LG tv shows av inputs as black & white
you need to plug all three colors in not just yellow
red blue green need to be pluged in their respective colors
Chi Chu
  • 8457 Answers
  • Posted on Mar 10, 2010
SOURCE: the tv does not power on. it just flashes red and
Power supply board is dead.Tries Websites Shopjimmy.com,Ebay.com to buy a reburbish power supply board for the replacement.
Is the module of lg tv 32ld330-mb affected when theres a lighting strike???is there a chance to be fix??
The damage from a lightning strike tends to be random. Sometimes it's minor, and only a few parts are affected. Other times, many parts are ruined, or destined to fail soon as a result of the current surge.
If the strike came over the power line, the input surge protectors in the power supply should be replaced, even if they look good. It would be prudent to replace the entire power supply. If you had the set plugged into an external surge protector, that should have taken most of the hit and should also be replaced. (Some surge protector manufacturers will pay up to a certain amount for repair or replacement of equipment plugged into their products if it is damaged by lightning.)
If the lightning came over an unprotected input cable, fixing the set would be a gamble. You could end up changing a lot of modules, beginning with the main board.
Connect tv to iPad NO SIGNAL problem
Check the input or source on the TV to make sure it is on the correct input for the ipad.....
4helpful
2answers
Only one (out of four total) HDMI input is working on my set.
The HDMI switcher IC chips in TVs can be damaged but lighting hits near you house even if the power is protected with a surge protector. The damaging power comes in through the HDMI port and blows the chip out and it can affect just one port or multiple HDMI ports. Your best bet would be to just get a cheap HDMI switcher and use the one working port. The repair on the TV would require placing the control board and would run from $75-150 for parts plus the labor to install it.
Does this plsma tv habe hdmi inputs
If you mean the LG 60PC1D, it has 2 HDMI (HDCP) ports on the back of the TV. They should be just to the right of the Coax Antenna In connection on the lower left of the input panel. To the right of the HDMI ports are the VGA (PC RGB), PC audio in, and a RS-232 port. Crutchfield has the manual available as a PDF here: http://a248.e.akamai.net/pix.crutchfield.com/Manuals/689/68960PC1D.PDF . See page 9 of the manual for the normal rear panel input arrangement.
I hope this helps.
I have a LG 47 inch flatscreen.i cant find any audio output plugs to hook it up to surround sound.how are you supposed to hook it up.
this is from the LG website about that TV.
- Rear,
2 x Composite video/audio input (RCA phono x 3) - Side,
2 x S-Video input (4 pin mini-DIN),
1 x USB (4 pin USB Type A),
1 x Audio line-out (RCA phono x 2),
2 x Component video input (RCA phono x 3),
2 x Audio line-in (RCA phono x 2),
1 x Digital audio output (optical) (TOSLINK),
1 x Digital audio output (coaxial) (RCA phono),
3 x HDMI input (19 pin HDMI Type A),
1 x RGB input (15 pin HD D-Sub (HD-15)),
1 x Audio line-in (Mini-phone stereo 3.5 mm),
1 x Serial (9 pin D-Sub),
1 x Remote control (Mini-phone 3.5 mm)
What cable do I need to set up the HD and where do I plug it in? All the ones I lookes at have a rectangular end and I don't see one on the like that on the TV. I am using the 2 scart sockets for cable...
Any of these will work.
ANTENNA IN: UHF/VHF 75 ohm Din type (If in HD Broadcast)
EXT 1: SCART (AV Input/Output, RGB Input, TV Output)
EXT 2: SCART (AV Input/Output, Y/C Input, AV Link)
EXT 3: S-VIDEO (Y/C Input), RCA pin (AV Input)
EXT 4: RCA pin (Vomponant Input)
PC INPUT: D-sub 15 pin (ANALOG RGB), 3.5mm Javk (Audio Input)
Service Manual can be found here: http://www.givemefile.net/smanuals/lcd_tvs/sharp/file/45437.html
2helpful
What type of audio jack rgb/dvi in on rear of lg 50ps3
the dvi out of pc via adaptor to hdmi on tv has no audio,ok.
so LG diagram shows separate audio into Audio in RGB/DVI.
Resulting in video in on HDMI ok,but audio on RGB.Can not get both together.
Fix is revert to DVI to RGB lead with audio on RGB/DVI input.
The audio jack would only work with mono plug for audio in, to RGB.
Green light is on ...white noise sound but no picture
This TV finds the connected input sources
automatically for AV1, AV2 and Component 1-
2. It is presumed that RGB and HDMI/DVI
sources are connected.
Check your setup to see if the audio is turn off but if you have a clear picture you should have sound.
Time to call a TV Tech if you are not going to repair the unit.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
