LG 32LG30 no signal when pc and tv r connected via rgb cord
I purchased a cord to be able to connect laptop to tv. I go to input on the tv, select rgb pc everything looks good. TV says no signal. What am I missing?
same with me says invalid formatsame with me says invalid format
AnonymousMay 06, 2009
i have the same issuei have the same issue
AnonymousMay 16, 2009
same here i have got a hp laptop that i want to use as my tv 43 inch lg plasma when i plug rgb my laptopan and my monitor goes black plz someone help plz.
thanks 4 advance any help will be apriceated same here i have got a hp laptop that i want to use as my tv 43 inch lg plasma when i plug rgb my laptopan and my monitor goes black plz someone help plz.
won t connect with password says not connected to a wireless network but i have internet. all cords ( 3 color cords and skinny cord connected to tv and ruku boxwon t connect with password says not connected to a wireless network but i have internet. all cords ( 3 color cords and skinny cord connected to tv and ruku box
AnonymousMar 17, 2014
What key combinations do you have to execute to start you TV to accept the streaming from the computer. We have it connected with a RGB CORDWhat key combinations do you have to execute to start you TV to accept the streaming from the computer. We have it connected with a RGB CORD
You can't post conmments that contain an email address.
Re: LG 32LG30 no signal when pc and tv r connected via...
For No signal try- Updating your Video drivers, and making sure it shows a connection on your laptop ( by going to propertys on desktop and then dysplay)
For format try- Updating and or turning down the screen resulotion becuase the size differs on screen even if you think it shouldnt.
Connect VGA (D-sub 15 pin) cable from PC to TV (RGB PC) input jack. Connect audio cable from PC to TV. Set screen resolution on PC to be compatible with TV, such as 800 X 600 or 1024 X 768 etc. Select on the TV, the PC INPUT using the TV remote when ready to use as monitor.
Under PICTURE on the TV select SCREEN (RGB-PC). You can AUTO-CONFIG or you can set resolution manually to the same you set PC to. Other adjustments can be done here as well to get optimum picture on TV from PC.
Reading the online manual -
You should have the laptop connected by VGA - PC input
VGA Connection
you need to select the correct input on the TV
Select the RGB-PC input source on the TV using the INPUT button on the remote control.
you will need to set the laptop up to output to the VGA output, to do this - varies by different manufacturers - But often F4 or F5, with the FN key selects the VGA output - have a look at the F keys across the top of the machine and see if you can see a picture of a screen - then use the FN and that F key together to toggle between display
it will change to <Laptop Screen Only><Laptop screen and VGA output><VGA output only> not necessarily in that order.
This is the support site for that TV
http://www.lg.com/us/support/product/support-product.jsp
direct link to the PDF user manual
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=37LG30&matchedModelCode=1000003995&searchEngineModelCode=37LG30&initialTab=documents&targetPage=support-product-profile#
Your right. I just had the same "Invalid Input" issue as well and it completely relates to the resolution compatability with any VGA or HDMI connection. Check the LG website for the online manual if you don't have it and see the section on RGB-PC cable. There is a table that incdicates the Resolutions the LG product is capable of displaying.
what laptop are you using?
what cord you get?rgb?
