Worked for 5 months then just stoped working
My toshiba 42" is the same way. Yesterday I watched netflix on it through the HDMI cable on my laptop, now it says no video signal
SOURCE: conecting plasma to receiver using hdmi lead
if you receiver has a Aux function an is still unused try to hook your playstation audio rca up to it directly it will work either way, Hope thats what you mean, An Hope it works
SOURCE: Passing HDMI signal fro cable box to yamaha RXV463 to Samsung HDT
It sounds like a resolution problem to me. Try adjusting the video settings on your set. It may need you to switch modes as some TV's do this (Why I dont know). I have found that even sometimes its the cable service to blame.
SOURCE: Hi, I have a yamaha rx-v465 av receiver and have
I need a connection Diagram for the RX-V465 Yamaha receiver
SOURCE: rx-v1900 hdmi hdtv problem
On most modern receivers you must select which signal type you want it to process.
for example on my Denon, I have to go into the on screen menu and select the input I want ie: video 1.Then tell it which signal I want it to use ie: s-video, component or HDMI input for video and then which input corresponds to the audio signal for that component ie: analog, digital, optical or hdmi.
Its complicated and a pain in the ****
Hopefully that helps call Yamaha they will usually walk you through the process while on the phone.
SOURCE: the picture on my TV
Hello Susan hi, you have a situation where the problem is the TV, OR the cable signal, to isolate, try using another TV, if the other TV produces the same result, meaning flicker are present, then you have the cable company to blame. If the flicker disappears on the other TV, then you have the part problematic. This will solve half the problem. finding the problem.
