Televison & Video Logo
Simon driver Posted on Jul 21, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No sound have no sound on certain channels
Anonymous
Level 3:
Genius:
  • Master 1,182 Answers
  • Posted on Jul 21, 2012
Anonymous
Master
Level 3:
Genius:
Answers
1182
Questions
Helped
292607
Points
3377
No sound on certain channels can only be due to problems in the input device. Try connecting the TV to some other input device. Use a head phone and see. Look for any jammed buttons on the remote. If you notice same problem, this may need attention by a qualified service technician.
Stereo SAP will not come off a few channels , no sound on these channels
Do a factory reset to this set. The Secondary Audio Program [SAP] to all channels will be cleared. Refer its user manual for details.
1helpful
Hi leelee, some cable and air signal channels have a separate audio program in the signal(commonly known as SAP) it may be that the SAP is activated or turned ON in your TV. This no sound condition only shows up on those channels that have the provision for it, but the signal is not being transmitted, that's why you have no sound on those channels. You will have to look for the sound key on your remote control and deactivated from there, or you might have to actually select the menu and scroll down to audio features, it is sure that you will find the SAP feature turned on. Good Luck
No volume on certain channels
If you are using an antenna to recieve digital channels, if the signal strength is low on certain channels the sound will not be tuned in. Try adjusting the antenna. If it is cable there may be a problem with the cable run.
3answers
My sournd sound turns on then turns off can any one help
so is this sound on the tv or a sound system
YOU CAN ONLY CHANGE MANUALLY TO CERTAIN CHANNELS AND ONLY MSNBC H
You need to auto program the TV. this is done in the menu. If you are using cable you should make sure that you select CATV prior to auto programming
Radio automatic search
when your radio is on a certain channel the only thing it does is try to pick up that certain channel. say you go threw a tunnel or around the side of a hill. or in a residential neiborhood. the radio has a lot of interference from other things trying to pick up the same signal. there is nothing you can turn off or anything. as long as your getting a good sound on a certain channel leave it there,, when it don't pick up so good your loosing your signal and need to find a station that is closer to were you are. good-luck ray
Only left/right have sound during the test
all of the channel are resonding to the test. but you cant notice it bec 5.1 speakers, each channel are designed to respond to a certain frequecies.  the L/R channel your talking about have the mid-range frequecies so it responds clearly compared to other channels...
hope that helps...
1helpful
2answers
Sony Wega KV-27FS120
as no sound on certain channels it means no problem in your tv though it is old. the problem is in transmission line from where you get prog. it can be adjudted manually by vol.control if low sound is there at certain channels. you can also reset once.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
