Question about Astar LTV-3201 32 in. LCD Television
No sound on certain channels
Certain channels have no sound how can this be fixed and what might the problem be?
Posted by leeleelovesb on
Anonymous
  • 476 Answers
Hi leelee, some cable and air signal channels have a separate audio program in the signal(commonly known as SAP) it may be that the SAP is activated or turned ON in your TV. This no sound condition only shows up on those channels that have the provision for it, but the signal is not being transmitted, that's why you have no sound on those channels. You will have to look for the sound key on your remote control and deactivated from there, or you might have to actually select the menu and scroll down to audio features, it is sure that you will find the SAP feature turned on. Good Luck
Posted on Apr 20, 2010
Why is there no sound on PBS channel 56.1 WTVS Detroit?
This seems to be a quirk on certain channels in certain areas. In my location, certain programs sometimes have subtitles only - no audio.
Nov 18, 2015 | Televison & Video
Interment or no volume on certain channels.
make sure set not set to sap mode as this can blank audio on certain channels
Sep 03, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
No sound
No sound on certain channels can only be due to problems in the input device. Try connecting the TV to some other input device. Use a head phone and see. Look for any jammed buttons on the remote. If you notice same problem, this may need attention by a qualified service technician.
Jul 21, 2012 | Televison & Video
Philips 32pf732198 no sound on certain channels
Unplug,replug the tv an hour later.Go to ur tv menu reset the Audio setting.The setting will go back to the factory setting,should work solved ur problems.Not than ur Tuner signal board have problems,must change.
Apr 06, 2010 | Philips 30PF9975 30 in. LCD HDTV
No volume on certain channels
If you are using an antenna to recieve digital channels, if the signal strength is low on certain channels the sound will not be tuned in. Try adjusting the antenna. If it is cable there may be a problem with the cable run.
Dec 27, 2009 | Dynex Televison & Video
My sournd sound turns on then turns off can any one help
so is this sound on the tv or a sound system
May 03, 2009 | RCA F32649 32" TV
YOU CAN ONLY CHANGE MANUALLY TO CERTAIN CHANNELS AND ONLY MSNBC H
You need to auto program the TV. this is done in the menu. If you are using cable you should make sure that you select CATV prior to auto programming
Dec 18, 2008 | Insignia LCDTV26 26 in. Television
Radio automatic search
when your radio is on a certain channel the only thing it does is try to pick up that certain channel. say you go threw a tunnel or around the side of a hill. or in a residential neiborhood. the radio has a lot of interference from other things trying to pick up the same signal. there is nothing you can turn off or anything. as long as your getting a good sound on a certain channel leave it there,, when it don't pick up so good your loosing your signal and need to find a station that is closer to were you are. good-luck ray
Nov 09, 2008 | 2001 Audi A6
Sony Wega KV-27FS120
as no sound on certain channels it means no problem in your tv though it is old. the problem is in transmission line from where you get prog. it can be adjudted manually by vol.control if low sound is there at certain channels. you can also reset once.
Sep 26, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Astar LTV-3201 32 in. LCD Television Logo
199 people viewed this question
Top Astar Televison & Video Experts
Marvin
Marvin
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
