MPC Computers Netframe 620 Server Logo
BobEut Posted on Jul 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
3 Beeps when I turn it on.
Been in storage for 2 years, turn it on and get three beeps, with red LED's in the back. I've moved around the SATA drives, put an IDE in and tried ,still three beeps right when I turn it on. No video . everythings running and i can hear the HDD spinning as well. what to do.
Anonymous
Level 2:
  • Expert 147 Answers
  • Posted on Jul 10, 2012
Anonymous
Expert
Level 2:
Answers
147
Questions
Helped
117114
Points
491
Remove RAM and clean it with soft cloth and attached it properly then power on your server. I will work.
Best of luck
5kg top washer not working, making a continuous beep sound
1) Test the voltage of machine vs the outlet wall from the house,
2) See if the frequency is 60hz or 50hz?
3) Tight the connectors very well inside, and tight any loose wires
4) Reset the machine. Turn off the c.breaker by 15 minutes, and tripped again, and Turn on again. If the problem persist you must call some service tech, the board can be faulty.
God bless you
Singer confidence quilter beeps 8 times won't sew
http://www.singerco.com/uploads/download/549_7469_efs.pdf
http://www.singerco.com/uploads/download/683_7469_efs.pdf
here are 2 links for a free manual, you can choose which one you need
try changing the needle
if you just bought the machine,, you may have to take it back & get
another one
Jun 08, 2012 • Singer 7422
Jet 3 ultra power chair won't move
Move the freewheel levers back and forth so the chair does not move drive position
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
1 LONG BEEP 2 SHORT BEEPS
Does anything ever post to the screen when you press the power button? if not, it's your video card. The links below are for 1 long and 2 short and they say it's the video card. I've heard that Sony extended the warranty on some models so you might want to go to their website and check yours or in a google search type: Sony GPU Extended Warranty. I did and I see they extended it from one to three years. They have the faulty Nvidia Graphics Card which was a major problem for many manufacturers.
Beep Code Links Below:
http://www.biosbeeps.com/sony-vaio-bios-beep-codes.html
http://www.techsupportforum.com/forums/f108/sony-vaio-vgn-ar51-beep-codes-614124.html
Extended 3 Year Warranty for Defective Nvidia Graphics Card links below:
http://apcmag.com/sony-vaio-notebooks-suffer-from-faulty-nvidia-gpus.htm
http://www.slipperybrick.com/2009/08/sony-warns-laptop-owners-of-defective-nvidia-gpus/
Running machines broken
Dear Sir:
Please adjust, clean very well, and tigh the connector from Reed switch see the diagram attached.
2) Tight the flexible cable from keypads + connector from display board vs lower board.
After your fix it RUN the software calibration for diagnosis +trouble
sincerely. God bless you
Alesis ProLinear 720 DSP Speaker Stopped Working
This Post is UNBELIEVABLE!! I have a ALESIS PROLINEAR 820 Monitor that just in the last year HAS THE SAMEEEE EXACT PROBLEM ... it powers on TURNS green but all you can hear is some faint white noise coming from the tweeter ANDDDDD to top it off My Volume knob on the back doesn't cut off anymore it just turns all the way around and around JUST LIKE YOURS ... I SURE hope you get this message update bc I'd like to know what the outcome of yours was, !! Bc whatever the problem yours had , mine obviously has the same identical problem !!! Please message back if you get this ! Thank you so much. !
Forgot the combination to the lock. Is there a way to retrieve the combination or return it to its factory default combination 1, 2, 3, 4, 5
The instructions below are copied from the programming instructions (page 11):
ERASE ALL PROGRAMMING
(The "out of box" factory default will be restored)
1. At the back of the lock, remove the screw at the bottom of
the lock housing and remove the cover.
2. Take out the battery pack and remove battery power by disconnecting
the battery pack.
3. Plug in the (provided) male shunt connector into the yellow
wire female connector.
4. With shunt connector connected, re-connect the battery
pack. The lock will immediately sound 3 short beeps (if
these 3 beeps are not heard, then restart at step 2).
5. The lock will then sound more slow beeps, 1 beep for every
second it takes to clear the memory.
6. After a few more seconds, the LED will slowly alternate between
flashing red and green--disconnect the yellow wire
shunt connector.
7. The LED will continue to slowly flash green and red for 25
seconds. To enroll Function Cards, proceed immediately
as follows:
• With the lock LED slowly alternating between flashing
red and green, present the Function Card #1
to the lock. The lock will sound 5 slow beeps.
• The lock LED will flash green rapidly. The lock is
ready to enroll the Function Cards.
• Re-present Function Card #1 to the lock. The
lock LED will flash green then red, with two beeps
(indicating the card was enrolled successfully).
• Present Function Card #2 to the lock. Again, the
lock LED will flash green then red, with two beeps.
• Continue to present, in order, Function Cards 3-
9. Each time a new Function Card is presented, the
After the 9th Function card is presented, the lock LED will flash
green twice, sound two beeps, and will then remain silent,
ready for use. Note: If the lock continues to beep after presenting
the 9th Function Card, check to verify that the yellow
wire shunt is disconnected.
Note: If you only wish to use the first 3 Function Cards, simply
allow the lock to "time out" after 30 seconds.
Here is the link to the complete instructions, in PDF form. You will need Adobe Acrobat or equivalent to view them:
http://napcosecurity.com/download/PL3000_WI1280A.04_PROG.pdf
Good luck-and please provide feedback if this helps!
4helpful
2answers
I have a Graco baby monitor, it started making a noise for the last 2 days, could it be a battery problem (even with power connected)? The monitor is about 1.5 years old.
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months From Manual:) 5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on. 6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off. A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now ready for use. 7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above. 8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and the connection LED should change from red to green. You may hear an audible beep during this process. 9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate. Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and the bottom LED will be red. 10. Repeat steps 5
1helpful
Kenmore model 417-44052400 front load washer error code E04 (5 vertical LED flashes & beeps and 4 start led flashes. I ran the diagnostic test, it dose everything up to tumble, it won't tumble or...
Take the front lower panel off 2 or 3 screws you will see the pump.You will see a black "baffle" atatched to the pump.squeeze it feel a sock?Take the boot loose and clear.Only other thing would be the motor control board back let hand corner replaced many of these when tubs dont move.I hope this helped.
Top MPC Computers Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
