Jet 3 Ultra Power Chair Logo
Anonymous Posted on May 25, 2012
Jet 3 ultra power chair won't move
My chair will turn on but will not move. when i turn it on it beeps 2 times and the light go from red yellow and green 2 times then it flashes red and yellow until i turn it off. It will not let me unlock the chair i know how to tr y to unlock it but it wont let me i turn it on and try to push the stick up it never beeps and when i pull the stick back it doesnt beep. it will let me hold the power button and lock the chair but doesnt make the noise it should to unlock it. my niece was pressing the buttons and this is how it got broken. please help me to fix the chair
  • Anonymous May 25, 2012
    the joy stick is pushed to the left causing it to not unlock so i have to hold it in the center lock it and then unlock the chair and it works. i am not sure if they sale just the joy stick for them or if i have to replace the entire part for it. the part is way too much money so it willhave to work for now. thanks for the help.
  • Anonymous Apr 20, 2013
    we got a jet 3 it will blink and shut off and not move we got new batries we charged it what do we do
Scooter Doctor
Level 3:
Master:
  • Jet Master 401 Answers
  • Posted on Oct 10, 2017
Scooter Doctor
Jet Master
Level 3:
Master:
Answers
401
Questions
0
Helped
122699
Points
1542
Move the freewheel levers back and forth so the chair does not move drive position
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
5 Related Answers
Anonymous
  • 37 Answers
  • Posted on Jun 23, 2009
SOURCE: I have the jet 3 power chair. It was turned on and will not turn off. Just makes a beeping noise. Any idea what this could be and how I fix it?
Try a few things. First, push the reset button located on the bottom of chair right next to the foot rest. If that doesnt work, take the back outer covering of the chair and disconenct the battery connector and wait a few minutes then reconnect it. Also check the 50 amp fuse located behing the foot rest, take the pin off the bottom of the foot rest and expose the batteris and you will see the fuse.
Anonymous
  • 29 Answers
  • Posted on Sep 07, 2009
SOURCE: pride mobility Jet 3 Ultra Power Chair 7 flashing
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. [email protected]
Anonymous
  • 6 Answers
  • Posted on May 12, 2010
SOURCE: The lights blink but it want move when you pwer
The chair is in lock mode. To unlock, turn on, when the lights start to scroll, push the joystick forward and keep it there until you hear the beep. When it beeps, pull it back and wait for the beep, once the beep sounds let go and listen, if you hear a high pitch beep, success. If it doesn't work the first time, just do it again. Sometimes it may not work right away but don't panic, just follow the steps again.
Anonymous
  • 177 Answers
  • Posted on May 27, 2010
SOURCE: no power to motors joy stick does not woirk
Hi. If you count how many lights were flashing and let us know then I can look up that fault code and tell you what it is. Do you have the free-wheel levers in the correct place? Check the motor and battery connectors. How old is the machine, are the motors or brakes faulty. The machine will not operate if the charger is still connected. Good luck. Neil.
Anonymous
  • 177 Answers
  • Posted on Jun 22, 2010
SOURCE: Pride Jet 2 power chair with with 3 red and 3
Hi. The fault code you have is called the "Inhibit active".
It can be caused by a blown charger fuse, which causes the charger inhibit to activate.
Also if the 3-pin charger inhibit connector is not plugged in properly, or the connector is faulty, then the charger inhibit feature will activate.
Hope this helps. Neil.
2answers
Jet ultra 3 turns on but lights just continuously flash.
INFINFB2045 Jet 3 Ultra Troubleshooting
https://www.pridemobility.com/.../troubleshooting/infinfb2045_jet_3_ultra_ troubleshooting.pdf
File Format: PDF/Adobe Acrobat
troubleshooting instructions for the Jet 3 Ultra Power Chair. ... What if the systems on my Jet 3 Ultra seem to be "dead" (controller does not light up when the on/off key is ... you continually allow the battery condition meter LEDs to fall into the red area, the ... 1 Flash. The batteries need charging. Check the battery connections.
Power on , no flashing lights. 3 red 4 yellow, no green. Battery measures 24.6vdc, amp meter always at zero, why no green lights This is a Jet 3 Ultra power chair
Hi u cant rely on battery voltage it won'tell u the condition of the batteries....
The BATTERY'S HAVE TO B LOAD TESTED
ONE AT A TIME WITH A 12 VOLT LOAD TESTER
AVAILABLE ON E/BAY COST APROX $30
THIS WILL GIVE U A GOOD INDICATION ON THERE CONDITION....cheers
Chair won't move..lights flash continuously
You may have locked it by holding the power button . try turning it on then hit thee horn 2 times . That should unlock it.
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
1helpful
2 yellow lights are lit up
2 yellow and 3 red is code 5 - indicates that there is a problem with your right motor wiring. Check the connections to your right motor.
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
1helpful
Pride Jet 2 power chair with with 3 red and 3 yellow lights flashing. Batteries checked ok under load, all connections have been checked. I moved the chair and it would not move again. Just that quick.
Top Jet Health & Beauty Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
