20 Most Recent Pride Jazzy 1103 Ultra Standard Power Chair Questions & Answers
2answers
CHAIR IS CHARGED UP BUT
ajnss I need more information. can you turn the power on at the joystick? are you getting all the lights for battery level lit? are any of the lights blinking on the joystick? do you hear a clicking noise when you try to move the chair? Give me as much info as you can thanks
8/11/2022 3:33:05 AM • Pride Jazzy 1103... • Answered Yesterday
How do i obtain the electrical diagram for a jazzy
Hi
The Jazzy 1103 PDF document contains a lot of the electrical diagrams I've got it if you send your email address i'll send it 2 u. put the word at in place of the @ that will stop you getting sent spam
Tony
5/26/2022 6:19:04 AM • Pride Jazzy 1103... • Answered on May 26, 2022
2answers
Pride Jazzy 1103 Ultra: Bought used and came with new batteries. Worked fine until a week or so ago. Then died and couldn't be recharged (on-board charger). The seller kindly sent an external
a cheep fix is the charger I am showing you from Advance auto it will bolt into stock location and bolt to battery post you will need to make a jumper wire to send batt. voltage to joy stick controller well worth doing the modification to save big $$$$.
1/28/2022 5:04:49 PM • Pride Jazzy 1103... • Answered on Jan 28, 2022
This isn't a normal sound. The scooter whistles loudly and constantly as I go along and it is loud enough to bring people out of their houses. This should not be.
Take it in for service. It sounds like it has been modified or something is stuck in the motor fans. We are Fixya, we aren't the maker of your unstated make and model scooter. I moved the question for one of our mobility scooter Categories, purely as a guess!
12/14/2021 5:36:36 PM • Pride Jazzy 1103... • Answered on Dec 14, 2021
2answers
What batteries for Jazzy power chair?
Hello you may check this out. You can also buy the batteries here.
9/29/2021 12:15:24 PM • Pride Jazzy 1103... • Answered on Sep 29, 2021
Wiring Diagram for Pride Jazzy Q1121 Wheelchair
It isn't published anywhere. You will have to contact them direct and prove that you are competent to deal with the electronics. https://www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_q1121_om.pdf //
6/10/2021 4:28:04 PM • Pride Jazzy 1103... • Answered on Jun 10, 2021
Lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
9/11/2019 5:34:16 PM • Pride Jazzy 1103... • Answered on Sep 11, 2019
Will not operate.
hello,i love being of help,im disabled myself.if i help,it would be nice for you to say thanx,but i am not here for prsonal gain,but because i care. Now onto your answer you require,i recently visited shoprider homepage & downloaded a PDF File of a troubleshooter for my scooter also in the troubleshooter was the troubleshooter for an electric wheelchair.it had so many useful tips & depending on what the joystick displayed,that was your guide to solving your problem.you can also print off the troubleshooter for future,try it with yours.& if your not up on computer skills just ask someone in your family.i hope this helped you Colin.
6/3/2018 6:59:54 PM • Pride Jazzy 1103... • Answered on Jun 03, 2018
2answers
I got new batteries put
Has the chair been put in "manual mode"? Make sure of this and that batteries are secure.
2/14/2018 1:02:07 AM • Pride Jazzy 1103... • Answered on Feb 14, 2018
Will not power on how do I reset it
https://www.pridemobility.com/.../US_Jazzy/US_Jazzy_1170_om.pdf On page 16 is the location of the circuit breaker.
9/3/2017 7:17:07 PM • Pride Jazzy 1103... • Answered on Sep 03, 2017
2answers
How to reset controller on jazzy power chair
yellow light is flashing and i can't turn chair off. still operates.
5/5/2017 10:11:14 PM • Pride Jazzy 1103... • Answered on May 05, 2017
2answers
Plug charger in and will not charge the fan on the
David Are you leaving the power on while you are charging the Chair? If you are try charging with power off at the joystick. The manufacturers of all power batteries do not recommend charging with automotive chargers. I would try to locate a friend or neighbor that also has a chair or scooter and borrowing their charger for a few hours to see if it will charge your chair. If not contact your provider and borrow a charger from them. If the different charger works then yours is bad. You shoud be able to order a charger through your provider or by calling Pride Mobility @ 1-800-800-8586 Hope this helps you PS I didn't say you couldn't use the "other" charger. But I wouldn't want you to think I approved of it
11/28/2016 8:22:29 AM • Pride Jazzy 1103... • Answered on Nov 28, 2016
How to take seat off
Try this https://www.youtube.com/watch?v=mkCEL5MotSg
11/3/2016 5:16:25 AM • Pride Jazzy 1103... • Answered on Nov 03, 2016
We had the batteries replaced on 3/30/16 and now the red light is constant and when we charge it .. nothing changes... it barely moves and I do not believe it charges... the batteries are new
They have complicated control computers and are very touchy concerning the amount of voltage in various parts of the system, such as how much current the motor is drawing. Sometimes transmissions go dry of oil causing the gears to bind, throttles develop oxidation on the contacts, terminals get corroded. I had to bypass my original unreliable controller completely with a DC variable speed board from China. Test your batteries by connecting each to their own standard car charger. Get the back wheels off the ground with blocks and test run the motor while connected to the chargers. And test each battery with something powerful that can determine its strength, not just a small test light.The chargers are reliable, but the control brain (module) maybe not. Make sure your batteries are not dry, make sure fuse is OK, terminals are clean, charging system must be unplugged to run, test test test. Make sure the speed limiter is tried in various positions, parking brake or lock is in correct position.
5/13/2016 4:16:18 PM • Pride Jazzy 1103... • Answered on May 13, 2016
How do you adjust the front springs s0o that the rod wont bnd and break?
Pride Mobility Jet 7 (Power Wheelchairs) - USA Techguide
www.usatechguide.org/itemreview.php?itemid=929
13 posts - ‎11 authors Anti-Tip Wheels 6&8221; solid; front-mounted • Suspension Limited. ... get either aPride Jazzy, or a Jet 7, you'll be very happy, as long as you can afford a lift ... If youdont, the charge keeps going down, and will not ever recharge back to the ... These products need to be charged about 8 hours a day after usage, so its better ...
12/1/2015 1:11:52 AM • Pride Jazzy 1103... • Answered on Dec 01, 2015
When plugged in the speed yellow light flashes, when I unplug I get nothing. batteries are charged, seat is all the way down, wheels unlocked.
What is your question? Just what is the problem? Is it running?
11/22/2015 5:35:28 PM • Pride Jazzy 1103... • Answered on Nov 22, 2015
All red lights flashing. both battreys @13.5V 26V going to joy stick. Does't do anything.
Hello,repeat that to a service person.They should be able to give you a price for the job.
10/29/2015 7:32:13 AM • Pride Jazzy 1103... • Answered on Oct 29, 2015
Single red light plus 4 yellow lights flash continuously. I just installed new batts. The light chart does not show this condition. Any help?
Hello,type your issue into YouTube Videos.I am sure you will find what you are looking for.Just remember,if you attempt repairs yourself.Take a Step by Step pic guide,as repair people may not want to look at it.Being you worked on it yourself.
10/1/2015 4:01:34 PM • Pride Jazzy 1103... • Answered on Oct 01, 2015
Pride Jazzy 1103 Ultra Standard Power Chair  Logo
226 questions posted
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Pride Health & Beauty
Most Popular Question
diagram wiring 1121 jazzy wheelchair
  • Health & Beauty
