MACHINE WAS SET ON SMALL LOAD AND MACHINE FILLED UP TO THE TOP WITH WATER AND DIDN'T TURN OFF.
Possible that the water level controller is faulty and so needs to be checked as the pressure switch if defective will not work and so the inlet valve will not be cut off.
check this link for replacinmg inlet valve: Inlet valve
SOURCE: amana top load washer fills with water and will
Hi...
You need to check this
Good luck !!!
Regards
PCmania
SOURCE: My washer keeps filling with water even after the
The washer valve may be sticking if it allows water at the wrong time. The other part is a float (like in your toilet tank). Run a load of towels with a full load of water and 1/2 cup of vinegar no soap the first time normal the second time. The float should get a cleaning,withe the float eliminated (mechenicly) Test to see if it still over flows, If you have to get the valve replaced make sure there are screens with the washers so nothing else will get stuck again.
SOURCE: my top load ge machine does not spin. it fills
Sounds to me like the belt has either came off or has broken. You can remove the front lower panel to see if the belt is still intact.To remove, put a hand on each side of the panel toward the top. Pull toward you, the top of the panel will un-clip and pull out. Then just pick up on the panel and set aside. Now look for the belt. Pull on it and make sure it's tight. If not you will need to reinstall it of if broken, replace. Good luck.
