SOURCE: dynex-e402 change nat settings to access x-box live
Dynex DX-E402 router, changing NAT settings(UPnP) to access x-box live. go to router settings web page for router, http://192.168.1.1/, enter user name and password to access settings page. user id is usually admin this also for password. under advanced settings click on forwarding. In listed sub-catagories click on UPnp. click enable. this should solve any NAT issues with X-box 360 signing onto x-box live. dynex dx-e402 was very easy to setup.
SOURCE: how do i set upa dynex dx-e402 i have a verizon
There are a few things you can do to help reliability
You should first make sure that the modem and router are individually
set up correctly.
I do have a guide for that.
Once that is done you should consider giving out proper IP addresses
Big business does this for security and reliability and it is no different for home users except maybe easier
Read the guide for router and modem first and if any of it may apply to you then try and do it.
The second part deals with IP addresses and this may well help you
I have a selection of computers laptops servers at home on a small network
It is quite some time since I last had to do any sort of system wide shutdown
Try the following procedure and write down anything you change so that if you need to go back you know what was changed.
Connect ONLY the MODEM to a pc and nothing else
Go to the start menu and select RUN
In the box type "cmd"
Now in the black screen that has come up type "ipconfig /all"
Take note of the numbers that are in 4 groups e.g. 192.168.1.1
Also take note of the name in front of those numbers !
Take note of the DEFAULT GATEWAY
Now do the same thing with your ROUTER
If that too has the same IP as your modem in "default gateway" then you need to fix that issue as that is probably a part of your problems.
The fix for router modem conflict is to set the router to use a different IP range.
SOURCE: i need to forward port 80 on my DYNEX dx-e402
GO HERE www.portforward.com theres instructions there on how to forward your router
www.ziggy-links.com
SOURCE: how to connect a dynex (dx-e402)router to linksys
Configure the dynex on another computer that is not connected to the linksys router.
Assuming that your linksys is currently setup as 192.168.1.1
Turn off DHCP on the dynex and setup the IP to 192.168.1.2 subnet mask 255.255.255.0 gateway 192.168.1.1
use a cross over cable and plug each ends to the LAN port on port routers.
you should now be able to ping 192.168.1.2 (dynex router) from your other computers on the linksys router network.
any computer that is connected to the dynex should be able to get a dhcp address from the linksys router.
