20 Most Recent
Dynex DX-E402 Router Questions & Answers
After connecting my Dynex DX-E402
Typically wireless routers have one port labeled WAN and four additional standard network ports. The WAN port should be connected to your broadband device, typically a cable modem or DSL modem. You can configure your router with a direct connection to any of the standard ports connected to your computer. Your router must be configured to DHCP automatically with its connection to the modem through the WAN port. So to repeat, outside world to MODEM, then WAN port on router, the wired or wireless connection to your computer.
I'm using two Macintosh Computers.
I followed
Richard have you tried setting up static ip addresses on the MACs
If you have other p.c's on network with auto ip assignment then alter the DHCP server lease to 192.168.1.10 to 192.168.1.240
then make ip address static 192.168.1.241 subnet mask 255.255.255.0 default gateway 192.168.1.1 and on the other mac
make ip address static 192.168.1.242 subnet mask 255.255.255.0 default gateway 192.168.1.1
http://www.macinstruct.com/node/550
I'm trying to to configure
Hi.
The number you need to put in is 192.168.1.1
That almost always is the default gateway address to the router that you are connected to.
Once in a while, it will be slightly different...i.e. 192.168.0.1 or 192.168.2.1 or something similar to that.
If you type the ones I have listed into your browser, it should connect to your router.
Now, as far as passwords go, if you didn't write the correct one down, then you will have to reset the router.
To do that press and hold the reset button in for 15-20 seconds with the router powered on.
After that the router will be reset back to factory settings.
Then type in 192.168.1.1 in your browser, and it will ask for username and password.
In both those blocks type in the word ADMIN.
These are the factory user names and password combination set by the factory.
I hope this helps you out.
Good luck, and have a good day.
What is the access number
Those number look like three fourths of the IP address. It's not the access number. The access number is created by the person who installed your router or it can also be the default number found on the label of the router - consult your router's user manual for a definitive answer.
I have a nettalk phone.
There has to be a small hole (usually at the back of the router). Inside this hole is a button. Use a paper clip to push this button for about 10 seconds fro the router to reset.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
I just got a e402 and cannot login to get the
The default userrname and password for the DX-E402 router are "admin" for both fields, so as long as they have not been changed, you should be able to log in by going to 192.168.1.1 in your web browser and entering the username and password.
I'm trying to get a dynex DX-E402 to join my airport express
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
I CANT GET IT TO WORK WHY?
Make sure that the physical connection is correct... modem to the Internet port on the router and PC to any LAN ports... If you have cable connection, it should connect automatically if not try to do a powercycle... turn off everything and turn it on after a few mins starting from the modem (wait til lights are steady) then turn on the router and then PC
Router will not work even after depressing the
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Having problems with connecting xbox 360 to this
Are you trying to connect X-box to the network ?
I believe you know all the wireless settings of the router.
If not then check the wireless settings of the router. Make Sure that the wireless MAC filter is disabled. You may need to reduce the MTU on the router and open the ports on the router
Click Here for more info on how to connect X-box
Trying to hook up router. What is the wan for and
The WAN port is the physical interface that provides input and output to and from the device that provides Wide Area Networking capability .. i.e. the modem that connects to your Internet Service Provider. The usual choices are a DSL modem, a cable modem or a Wired router or a wired switch.
The 4 other inputs are wired inputs and outputs for wired Local Area Network connections.
The WAN port normally connects to the Internet. It is not necessary to connect anything to the WAN port to have a network. But without one of the usual devices, you will not have access to the Internet.
The LAN ports connect to the network interface port on the individual computers that are part of the local network. One port connects to one computer.
A large system will have routers connected through the LAN ports to the WAN ports on sub routers and so forth.
