20 Most Recent Dynex 802.11g Wireless-G Desktop Card Questions & Answers
XP driver for Dynex DX-WGDTC does not drive
The driver for DYNEX DX-WGDTC is free and the following link.
http://www.dynexproducts.com/productSearch.html?query=pci+wirelesses&resultsPerPage=all
3/11/2020 8:29:33 AM • Dynex 802.11g... • Answered on Mar 11, 2020
I try to install the
install latest driver or troubleshoot
5/4/2011 6:35:26 AM • Dynex 802.11g... • Answered on May 04, 2011
Does dynex DX-WGDTC wireless desktop work for
The DX-WGDTC adapter is not compatible with Windows Vista. It was designed to work with Windows 98 through Windows XP. However, you can try to use it with a Windows Vista system. What will happen a lot of times is that the router will provide basic functionality but it may display some quirks, or it may drop the connection occasionally.
You can get a decent Wireless-G adapter for $30 or so, so you're probably better off just buying a Vista-compatible adapter, but if you already have this one, might as well see if it will work!
12/7/2010 12:19:31 AM • Dynex 802.11g... • Answered on Dec 07, 2010
Error code 10
10/28/2010 1:34:06 AM • Dynex 802.11g... • Answered on Oct 28, 2010
2answers
Dynex Enhanced Wireless G Desktop Card
Installing a Wireless PCI card requires opening the cpu case. Be careful to unplug the system before attempting it.
This tutorial should guide you in the right direction
http://compreviews.about.com/od/tutorials/ss/DIYPCICard.htm
7/10/2010 9:02:28 PM • Dynex 802.11g... • Answered on Jul 10, 2010
Wireless router disconnected
hello Gene1945US,
  1. Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  2. Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  3. Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  4. Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  5. Click on "Properties."
  6. Select the "Wireless Networks" tab.
  7. Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Available Networks" section.
  8. Click on "Configure" when you see your network's SSID in the "Available Networks."
  9. Enter your network's SSID and WEP key.
  10. Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
Please let me know if you have any further questions or concerns.
Thanks.
5/24/2010 11:13:48 PM • Dynex 802.11g... • Answered on May 24, 2010
Win XP Pro freezes when trying to use the Dynex wireless G card
Dynex Wireless-G Desktop Adapter is making my Win XP freeze within seconds after logging in. I've tried uninstalling, installing about 5 times. I'm doing everything by the install directions, nothing seems to help. It's a Compaq Presario Desktop.
Any help would be appreciated
3/8/2010 8:42:34 PM • Dynex 802.11g... • Answered on Mar 08, 2010
AFTER INSERTION OF THE WIRELESS CARD MY DESKTOP
The card is faulty.
2/27/2010 1:06:59 AM • Dynex 802.11g... • Answered on Feb 27, 2010
I dont have the cd to download so my wireless card
go to the manufactuere website of your wireless card and look in downloads your file will be there download and install it
10/8/2009 9:07:16 PM • Dynex 802.11g... • Answered on Oct 08, 2009
Wireless card unable to connect to network
http://support.microsoft.com/kb/928233
its a issue with dhcp probly check this out
6/1/2009 5:39:10 AM • Dynex 802.11g... • Answered on Jun 01, 2009
2answers
I have a new Dynex 400 Watt ATX power supply. Yesterday,a piece of plastic popped out of the power supply and was hitting the fan.Please advise if power supply is safe to use. Thanks, Jim
Hi Jim, Some psu manufactures put a plastic sleeve over high voltage components as a safety measure. Is the piece you have flat or tubular?
3/20/2023 1:17:26 PM • Dynex Computers... • Answered Yesterday
2answers
Dynex 1.3mp driver update for windows 7
Unfortunately, Dynex no longer provides driver updates for their 1.3MP webcam on Windows 7 as the product has reached its end of life and is no longer supported. However, you may still be able to use the webcam with the existing drivers that came with it or with the generic drivers that are built into Windows 7. To check if your webcam is recognized by Windows 7, follow these steps:
  1. Plug in your Dynex 1.3MP webcam to your computer's USB port.
  2. Click on the "Start" menu and select "Control Panel".
  3. Click on "Hardware and Sound" and then select "Device Manager".
  4. Look for the Dynex webcam under the "Imaging devices" or "Cameras" category. If it is listed, then your webcam is recognized by Windows 7.
If your webcam is not recognized by Windows 7 or is not functioning properly, you may want to try downloading and installing a third-party driver update software like Driver Booster or Driver Easy. These programs scan your computer for outdated or missing drivers and automatically download and install the latest versions for you. Alternatively, you can try searching for a compatible driver on third-party driver download sites, but be cautious as some of these sites may contain malicious software. It is always recommended to download drivers from the manufacturer's website or from trusted sources.
3/18/2023 1:33:28 PM • Dynex Computers... • Answered 3 days ago
I have a Dynex keyboard that is plugged into a chrome laptop and it isn't functioning.
Plug the keyboard into another device and if it works, then your Chrome laptop is at fault. If the keyboard does not work in a different device, toss it and buy another one, unless it's new, then take it back to the store where you bought it.
4/28/2019 3:57:10 AM • Dynex Computers... • Answered on Apr 28, 2019
Mi tv dynex se pone por favor espere luego dice se a bloqueado entrada
This sounds like you need a smartcard or your current smartcard is not working anymore. Your local provider probably "scrambles" the service over the line and you need to buy a certain subscription to see this channel. Please get in contact with your cable provider.
1/17/2019 6:27:29 AM • Dynex Computers... • Answered on Jan 17, 2019
Hi, My wireless dynex mouse doesn't work properly. The cursor jumps here and there. It's difficult to point to the target intended. thanks
go the the manufacturers web sit for the make and model of the mouse download the driver compatible with your operating system , and run also you can go to control panel select the mouse section and check for compatibility in properties section it is there that you can alter mouse speed , clicks , scrolling and the like
8/29/2018 3:11:17 AM • Dynex Computers... • Answered on Aug 29, 2018
Have a dynex optical mouse model # DX- PWLMSE how does it connect
The Dynex DX-PWLMSE uses a 27 MHz frequency wireless connection between the mouse and a specific USB receiver. For the specifications, see https://www.dynexproducts.com/pdp/DX-PWLMSE/8632063 . To use the mouse, you need to press the Eject button behind the scroll wheel. This lets you open the battery/USB storage compartment. Put two AAA batteries into the mouse. Then remove the USB adapter (it's between the two battery slots). Close the storage compartment and put the USB adapter into an available USB 2.0 slot on the computer with a version of the Windows OS above Windows 98. (Note: the specifications I see indicate Dynex wrote drivers for Windows Vista. It may not work with Windows 7, 8 or 10.) Make sure that the computer is on and can get driver updates from on-line sources. Turn on the mouse and it should auto-pair with the receiver. If there is no response, try pressing and holding the connect button on the bottom of the mouse. I'm not aware of any vendors that sell the USB receiver for this mouse. The manual for the DX-PWLMSE is available from Manuals Lib: https://www.manualslib.com/products/Dynex-Dx-Pwlmse-Wireless-Optical-Usb-Laptop-Mouse-4908.html . I hope this helps. Cindy Wells
7/16/2018 11:04:19 PM • Dynex Computers... • Answered on Jul 16, 2018
Dynex 802.11g Wireless-G Desktop Card Logo
21 questions posted
Top Dynex Computers & Internet Experts
Mike
Donivan Wise
Steve Sweetleaf
Steve Sweetleaf
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Dynex Computers & Internet
Most Popular Question
xp driver dynex dx wgdtc not drive
  • Computers & Internet
