Do you want to resume?
SOURCE: Magellan roadmate 300 wont turn on!
I think the problem is with the internal power jack which tends to break. the part is MG361213 and is available at laptopjacks.com. You have to take the Unit apart and remove the old jack and resolder the new one which is a three pin unit.
Good Luck
SOURCE: Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
SOURCE: Reseting the Magellan Roadmate 360 to the factory settings
Hello there:
here is a couple of linkds that i was able to retrieve hopefully they will help you ok
best regards michael
SOURCE: my magellan roadmate 1440 will not turn on? Is
get a new one.. no way to fix unless u get a new battery
SOURCE: My Magellan RoadMate 1340 will power up to logo and "moving clock
Have you tried updating the software on your device.
Go to Magellan.com and download the Magellan Content Manger:
http://www.magellangps.com/products/map.asp?tab=0&PRODID=2216
Once you've installed Content Manger onto your PC, connect your device to your PC using the USB cord. The Content Manager will allow you to update your 1340 with the latest software and updates which 'should' fix the problem that you're having with your unit.
