After installing the router NO INTERNET CONNECTION appears... but with direct LAN setting the connection is ok
This sounds like a route problem. This can happen if the settings to the WAN are correct. If you are using a dialup DSL router check to make sure that it is connecting to your ISP. Same for a cable modem. Once you have verified that it is connected properly then set your WLAN gateway to point to the WAN IP number. if you are using DHCP for IP addressing for your wireless devices make sure that the gateway address is set correct also. Check DNS settings sometimes the ISP's DNS servers are not setup correctly or are not stable try using googles free DNS numbers of 8.8.8.8 or 8.8.4.4
am using smartbro please help
