Linksys Wireless-G WRT54G Router Logo
Posted on Dec 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Linksys wrt54g SRX200. I can connect to my router
Linksys wrt54g SRX200. I can connect to my router wirelessly but not through the ethernet. Ikeep seeing the message "a network cable is unplugged" I an also connect directly to my modem. What may be wrong?
Lisa
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 63 Answers
  • Posted on Jul 05, 2018
Lisa
Expert
Level 2:
New Friend:
Night Owl:
Answers
63
Questions
0
Helped
29782
Points
347
Are you dealing with linksys router problems? check out this article and follow the instructions to fix the problems.
How To Fix Linksys Router Blinking Orange Flashing Yellow Light
Anonymous
Level 3:
  • Linksys Master 32,281 Answers
  • Posted on Dec 19, 2009
Anonymous
Linksys Master
Level 3:
Answers
32281
Questions
Helped
7911702
Points
102259
It appears the connection between the Linksys and the modem is not working.
Try a different LAN cable.
Check the LAN cable from the modem to the Linksys, it should be connected to the WAN/Internet port on the Linksys.
2answers
Install wireless router without cd
Linksys Wireless-G WRT54G Router istallation
Connectivity issues with my srx200 wireless router
First take the ethernet cable one end should fixed with ur PC/laptop and other end connected to ur modem.finally configure the access page .
2answers
I have linksys router,it's connect with lan cabel but without lan cable router unable to connect to my laptop
All routers need to have a ethernet cord from the ISP Device. Most people run Laptops Wireless from there routers or if its stationary run another ethernet cord from an open port behind the router to your laptop.
Linksys router model WRT54GX2 SRX200 drops wireless connection on the laptop and the ethernet connection on the desktop. Connection drops for seconds then reconnects in seconds. By-passing the router and...
read on the router if its broad band , if is not , you will not be able to use it , so my advice to you is get aother linksys router with broad band on it .wish you all the best
SRX200 Im using Wimax internet, my router is connected to entranet. cant get connec with my laptop
Linksys wirelss G router has many issues.
It isn't compatible with many adapters. You are constantly resetting.
Internet connection problems
Sorry but that seems to be a pretty convoluted explanation. Here is how it should go.
Vonage unit connected to phone line(s) and cable modem. Linksys connected to Vonage box. Computers connected to Linksys.
Ethernet has a length limitation of about 300 feet before you need another switch (hub) or a repeater. Does your wire length exceed this?
1helpful
Connecting a linksys wrt54g to a netopia modem
Is this an ISDN modem?
Generally: Netopia Ethernet out -> Linksys WAN port with a standard ethernet cable.
(Not the yellow LAN ports! - They are for your computers/printers.)
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
2answers
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through 192.168.1.1.......
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
