Do you notice any error codes or noises? Often when a unit does not spin it is because it cannot drain. Check the drain hoses and possibly the drain pump, behind the front lower panel, and see if you notice any kinks or debris.Do you notice any error codes or noises? Often when a unit does not spin it is because it cannot drain. Check the drain hoses and possibly the drain pump, behind the front lower panel, and see if you notice any kinks or debris.
I pushed and hold the start+cancel buttons at the same time, the error code is E47, it means the door lock switch need to be replaced? Even though it is locked and the locked light is on. The washer seems to go through all the cycle except the last spin cycle to wring out the water. So I set it to spin only and it sound like a little water left got pumped out, then it agitates back and forth slowly then ends and exits at 7 minutes left on the 12 minutes spin cycle.I pushed and hold the start+cancel buttons at the same time, the error code is E47, it means the door lock switch need to be replaced? Even though it is locked and the locked light is on. The washer seems to go through all the cycle except the last spin cycle to wring out the water. So I set it to spin only and it sound like a little water left got pumped out, then it agitates back and forth slowly then ends and exits at 7 minutes left on the 12 minutes spin cycle.
There is no abnormal noise, the washer operates normaily except skipping the spin cycle completely. So I had to wring the water out of my wet clothes before putting them in the dryer, and it takes twice as long to dry because the washer can spin dry better the I could. I opened the washer and checked no kinks in the drain hoses, drain pump turns freely. Error code E47 tells me to replace the door lock switch. How do I check to see if the switch is defective/bad before I buy and replace with a new one.There is no abnormal noise, the washer operates normaily except skipping the spin cycle completely. So I had to wring the water out of my wet clothes before putting them in the dryer, and it takes twice as long to dry because the washer can spin dry better the I could.
wont spin because the unit is not drainning water...wont spin with water in it must drain first...check drain hose for kink,,,check waste pipe for blockage...and than check pump...onthejob
My washer is Frigidaire Affinity, model LTF6000ES0
