Question about Frigidaire Affinity ATF7000ES Front Load Washer
Ltf6000es1 frigidaire affinity won't spin belt
Ltf6000es1 frigidaire affinity won't spin belt is on and motor is turning manually. water comes in and out. unplugged to reset any computer board etc. still won't engage spin
Posted by plklaiber on
Anonymous
    New Friend:
How do you test the door lock Switch?
Posted on Apr 27, 2010
Anonymous
  • 254 Answers
Check the door lock switch assembly
Posted on Mar 09, 2010
My Frigidaire Affinity front loading washing machine model #ATF6000FS1 won't spin when loaded.What's the problem?
sounds like you have something in your pump stopping the water draining it will not spin with water try unblocking the punp
Sep 27, 2012 | Frigidaire Affinity Washing Machines
Frigidaire affinity washer error 58
High motor current is recognized in the unit:
1. Remove the belt from the motor and spin the motor pulley. Does the motor spin free? No, replace the motor. Yes, go to step (3). 2. Spin the tub pulley. Does the tub spin free? No, check the tub bearings. Yes, go to step (3). 3. Disconnect the plug from the motor and measure the resistance of the windings (pin 1 to 2, pin 1 to 3, pin 2 to 3). All readings should be between 4 and 6 ohms. If readings are correct, replace the Speed Control Board. If readings are incorrect, replace the motor.
Aug 10, 2012 | Frigidaire Affinity ATF7000E Front Load...
Dryer does not spin
see the causes:
Belt
broken replace
Motor
defective replace or repair
Door switch
test for open or defective replace
Jun 19, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Won't spin fills and drains water if i manually turn dial
Direct drive or belt drive? If belt drive then thats easy, motor belt or pulley. Direct drive? motor, ,,, maybe.
Jan 11, 2012 | Frigidaire GLTF1240A Front Load Washer
I have a Frigidaire Affinity dryer that shows power but when I press start it has a humming noise and wont spin.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 01, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Frigidaire front load washer wont high spin
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Apr 03, 2009 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire front load washing machine gtlf490e
First of all check the motor.most probably its got weak so its spinning when empty but not spinning when there are clothes in the machine. It doesn't spin If your washer won't spin, check these:
Jun 30, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
1,882 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
