20 Most Recent Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer Questions & Answers
Thanks to the different postings on the net about a E20 error code I took apart my washer’s drain system ATF7000 to find. A pare of little girls underpants, one hair band, one plastic green gem, a golf ball sized wad of wrappers/stickers/???, and almost two dollars in coins. All caught up in the plastic strainer located inside the black rubber boot found on the bottom of the tub leading into the drain pump.
Here is how I did it: After emptying the washer of sloppy contents, I sucked as much of the water out with a shop-vac. I then turned the washer onto it’s left side gently using a couple of towels as a cushion (unplugging the washer and hoses first). From the bottom and back panel you can access the drain hose/pump/coin catch. With a pair of pliers you can remove the clamp holding smaller end of the rubber coin catch to the tub, with a Phillips screw driver you can remove the larger clamp of the rubber coin catch to the tub. From the back panel you again use your pliers to remove the clamp to the drain line, and finally with a Philips screw driver remove the two screws holding the pump to the bottom of the washer. Oh yah, do not forget to unplug the wire from the pump. Now pull the pump out with the black rubber boot still attached. Mark the orientation of the pump to the boot with a sharpie pen, and remove the last clamp. Now look inside the black rubber boot and gently remove the plastic basket inside, there you will find the treasures that just wasted the last hour of your time. Now reveres those steps, reinsert the half washed clothes, and enjoy your new machine.
Thanks again to everyone that has posted before me, otherwise I wouldn’t have known were to even start looking. I hope this helps someone.
Frigidaire... • Answered on May 11, 2015
According to SearsPartsDirect.com ( http://www.searspartsdirect.com/washer-repair/error-codes/frigidaire-front-load-washer-error-codes.html ) : EF2 Condition Too much suds Check/Repair Reduce the amount of high-efficiency (HE) high-efficiency detergent being used in the washer.
I appreciate your inquiry, friend!
I see that you would like a list of Frigidaire Affinity washer error codes. I was unable to locate a full list of codes. Are you currently experiencing an issue with your washer? What error code is being displayed? With more information I will be able to assist you further. -Matt
Frigidaire... • Answered on Mar 16, 2015
it might be trouble on clog drain hose
Frigidaire... • Answered on Nov 28, 2014
Check the rinse hold has not been accidentally pressed . If not then you need to drain from the bottom plug and check penny trap.if that's clear it may be the pump or hoses that have clogged or failed.reset machine to off and try selecting spin only.
Thanks for your inquiry, friend!
I interpret that you are having trouble with your Frigidaire washer not stopping. Let's try resetting your washer by flipping the household circuit breaker to the off position. It is necessary to wait roughly ten minutes and then turn on your washer. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, I have identified that it could potentially mean a number of things: a potential wiring failure, control panel, or faulty door latch assembly. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dishwasher to determine the root cause to reduce the risk of unnecessary parts. -Matt
Frigidaire... • Answered on Oct 15, 2014
Good Afternoon Friend, this is Z. That's a great question! Most parts can be purchased directly from the manufacturer or through a parts distributor in your area depending on the part that you need. Hope this helps! If there is anything else that I can help you with, please feel free to reconnect!
Frigidaire... • Answered on Jul 15, 2014
Good Afternoon Friend, I understand you want to know how to replace the drive belt in your Frigidaire washer, model# ATF7000. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to replace the drive belt with ease. Hope this is helpful. -Best Regards- WP
Frigidaire... • Answered on Jul 10, 2014
Hi Richard, I want to help you with your Frigidaire Affinity washer, model# ATF6000ES. If the reddish oily liquid is coming from the bottom of the appliance, it could be grease coming from the motor area. If the liquid is coming from the dispenser area, it could be either coming directly from your water intake, or possibly a backup in your dispenser area. Hope this has helped. -Best Regards- WP
Frigidaire... • Answered on Apr 04, 2014
i believe that this diagnostic mode or show mode, please make reset and send me [email protected]
Frigidaire... • Answered on Feb 17, 2014
Open the lower panel and search for a trouble shooting tech manual. There inside the you'll find the error codes.
Frigidaire... • Answered on Feb 08, 2014
Probability is you have a blocked pump. That humming noise you are hearing on the spin, is the pump motor polling as it cannot turn. The machine will not spin until the water is out. This is the safety function of the pressure switch. Centrifugal force would otherwise cause the water to be forced out of the machine from places like the dispenser draw and flood your laundry. Regards John
Frigidaire... • Answered on Jan 30, 2014
too many possibilities, maybe best to call a repair guy. possible short circuit in any one of many sub-curcuits.
Frigidaire... • Answered on Nov 11, 2013
E21 is telling you that it has not drained the water out. You may have something stuck in your drain pump.
Sgt 48
Frigidaire... • Answered on Sep 29, 2013
more than likely the pump is clogged if you pull the the washer out away from the wall and then lean it back to get under it there is a hole to access the under side you can reach through to the pump then disconnect the large hose that goes from the tub to pump reach down inside of this hose remove the cup that has debris in it and clear it out remove the debris and reassemble the washer
Frigidaire... • Answered on Aug 08, 2013
The E20 code is a general pump failure code. This is usually the pump being clogged.Try using a wet/dry vacuum on the end of the drain hose to see if there is a blockage that you don't see. If you still get the error you will need to replace the drain pump.Here is the new drain pump to order.
Frigidaire... • Answered on Nov 26, 2012
Frigidaire Affinity ATF6000ES 3.5 Cu. Ft. I.E.C. Front Loading Washer Logo
84 questions posted
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
e21 error while final spin
  • Washing Machines
