Re: my rayban rb2113 hinges are not sitting flush.
Normally an Hair dryer would bo the job. Just hold the lens with a soft cloth and force a bit the arm while warming it a bit with the air dryer. Hope it will work. good luck
Recheck the door hinge install. Sound like the hinge is not installed properly leaving a gap on the hinge side. There are sometimes notches or hooks on the hinges that need to be in holes or cutouts on the washer body for proper fit. if the hinge is not in the holes right it will stick out from the body and leak.
Fluidmaster S2DBL Dual flush valve - would not flush The dual flush wouldn't work at all. So I slid the lid off part B (lever mounting base) and found the ball end of flush cable was not in the mating hole on lever arm. With needle nose pliers I pulled and pushed the ball into the hole and slide lid back on till it snapped. Snapped B to C (handle) - problem solved! RAP
The arm you are meaning is only the door stopper and is not supporting the weight of the door. It is possible that the door hinges and door post have changed in the position/alignment after the accident. So it is ideal that the door be taken out and the tinkering done on the door post , then the hinges can be changed or fixed to alignment of the correct gap.
Asked the same question. This is the answer recevied from rayban customer service: "The B15 is a brown lens and the G15 is a grey/green lens. Both lenses allow 15% light through the lens. It also blocks the UV reds and UVB rays".
the frost buildup is entirely due to badly fitting seals,its also costing you a fortune to run it.A 5 sided cube is easily adjusted by using a spirit level and spacers under the feet/wheels(if fitted)once adjusted the lid should fit square.otherwise check the hinges for adjustment.
WHEN FITTED/INSTALLED CORRECTLY, THE LID SITS TIGHT ALL ROUND,NO AIR GAPS.....
Check the lower hinge of that door for a broken closer cam. The upper hinge is adjustable and adjusting the corners in the front will shift the cabinet to align the door also. Eric
