Question about Ray-Ban RB 4105 Sunglasses
Ray ban rb4105 folding wayfarers the grey hinge on the brdige broke. the frame is alright so I think i just need to get that 1 part replaced.
Posted by j_juhng on
konstantino
    New Friend:
Please help me!!!!!i cant find a spare part for the hinge on the bridge of my wayfarer folding...what can i do???
Posted on Aug 26, 2013
  • Maria Garza
    Maria Garza Nov 20, 2013
    Did you find the part number? I need the same part. Please let me know if you found it.
2 Related Answers
tom sh
  • 1141 Answers
SOURCE: Hi,Wondering if all you sunnies aficionados are
The size is the width of the lens from the widest part. The larger the frame, the larger the lens. There is a slight difference in size in terms of the frame because the frame has to be able to accommodate the size of the lens, but the difference is not great.
Posted on Nov 07, 2010
DENNIS RICHARD
  • 118 Answers
SOURCE: the correct serial number on ray ban
look at the box your Ray-Bans came in. There should be a recycling logo, as well as a semi-permanent sticker on the box, including the serial number, manufacturer and distributor details, lens and frame type, and the model number of your specific style of sunglasses. If this sticker is missing, the sunglasses in the box are probably not genuine.
Posted on Jun 11, 2012
I need a replacement arm for rb2030 ps8 w2175
I'm in need of Ray Ban PS8 W2175 right temple as well.
Could anyone help, please?
(Or the whole frame, just to use the lens in good condition)
Feb 05, 2014 | Ray-Ban RB 2030 Sunglasses
How do you find out if Rayban Aviator are genuine or false? I have a couple of tips, but I wanted to know if there was some extra thing to check. Please do not tell me any obvious stuff like "go to...
These are the markings to check for.
Older Models made by Baush and Loma.
-Ray Ban B&L Made in the USA across the top part of the upper bridge.
-Size Markings on the paddles. (Only if they were not changed out, and are not the wrap around ear frames)
-Ray Ban white logo on the Right eye Lens. (Left if you are looking at the glasses) this should not come off easily like, with a cleaning cloth.
-B&L etched in the lenses, many knockoffs will have it painted.
-B&L engraved in the nose guards
Further information needed
Newer Ray Ban's made by Luxottica
-All newer Ray Ban's sold in the U.S.A will be made in Italy.
-Ray Ban Made in Italy under the top bridge
-Made in Ray Ban made in Italy CE on the inside right leg.
-Correct size and model info on the left inside leg.
-R&B etched in the lenses.
-Ray-Ban painted white on the Right Lens (Again won't come off easily)
Applies to both
-Should not have a mix of the above features....common mistake (Example made in USA across the bridge and made in Italy on the leg.)
-If painted, it should be enamel and should not come off easily.
-Hinges should have a distinct shape, not oval, and should not have any "burn" marks on the metal from being fused.
-The paperwork..sometimes called care book. (not the registration card) should be crisp with a professional work. Common fakes are printed with regular or shiny paper, haphazardly folded, sometimes colors will be bleeding, and or the English is full of typos.
-Mispelled words on the protective case if it has one. This should also match with the glasses. Luxottica with Italy made and Baush and Loma with U.S.A.
-Box is beat up or has Asian characters.
-Hinges should move smoothly but should not be loose. (Older/Used may require tightening.)
-Plastic lenses. An easy way to test this is to direct the car A.C. air at the lenses. Glass lenses will cool rather easily will feel cooler to the touch than plastic.
-Have them checked at a local sunglasses place, UV can be tested too. Many cheap priced sunglasses misrepresent the amount of UV that is blocked. Ray Ban's have a good reputation of Blocking that 99-100%
Jan 13, 2011 | Ray-Ban Ray Ban Aviator Sunglasses Metal...
Oakley vs. Ray Ban sunglasses? Which are better in brand, and which will last the longest.
I've never had oakley and they aren't really in style right now.
Ray Bans are good and the wayfarer glasses is back in style
as far as luxury brands, well it varies by brand. most luxury glasses are more for show or fashion than function. you really need to just try out different glasses to see what looks good and works well for you. If you want to go that route I would go actually try on glasses at sunglass hut stores and department stores to find what you like.
Polarized lenses are actually really cool. They cut down on glare so you can look at surfaces like metal, water and glass when it's sunny
http://www.wisegeek.com/what-are-polarized-lenses.htm
Nov 07, 2010 | Clothing Accessories
Any of you guys own G&G Black Wayfarer 80's Blues Brothers Sunglasses Super Dark? How is it?
The reason I bought these is because they resemble the sunglasses Ray Charles wore on certain occasions, and Ray also wore wayfarer shades on the cover of his 1962 country album. I play keyboards and they look very identical aside from the silver knobs on the top corner. I prefer these to ray bans not only because they are 70 bucks cheaper, but because they don't have any logos or signatures on the lenses, which kind of ruin the look a little. For being made in China, they are pretty sturdy quality and do not feel like cheap dollar store sunglasses and actually fit me pretty well. The lenses are pretty dark and reflect a lot, which only add to the benefits of this style. As for actually blocking out the sun, its decent but probably not as great as the more expensive ray bans, but who cares, they look just like a $75 dollar pair of Ray Bans, and don't have any annoying logos on the lenses, and the only difference between these and Ray Bans is the country they are made, and maybe slightly cheaper lenses and build quality, but why spend that much, when these look the same and look awesome, plus make for cheap replacement if you drop them or scratch the lens. You will feel just as awesome as Ray Charles and all the other celebrities that wore these from the mid 50s to today including Michael Jackson, Tom Cruise, John F. Kennedy, Billy Joel, Roy Orbison, Madonna, and Andy Warhol, which shows these sunglasses have wide appeal from every field of media and art. I'm looking at a picture of Michael Jackson wearing these, and they look exactly the same as these pairs, so they are completely in style and even though they kind of have an old fashioned 60s look to them, they are still great sunglasses and have been worn and endorsed by the world's most famous celebrities and figures for over 50 years.
What is there to know when planning on buying a stylish sunglasses?
1) One of the hottest trends of sunglasses this season is Ray-Ban's Wayfarers. This style of sunglasses
was particularly popular in 1950's and 1960's. This year thay made a significant came back. 2) The 70's style thicker frames have been popular for a few years already. However, you should be very careful if you decide to choose these retro style - inspired protections of sun. They should be appropriate for your face features and not to look too big.
3) Tortoise shell glasses are all still very hot this year. Stylists think that they will probably go out of style soon, but this year they are still fashionable. They are universal because they can be worn with any style of clothes. A good investment for a difficult financial times!
4) One of the lattest trends in sunglasses are the gradient lens. These sunglasses emphasize lenses, which are usually half shaded from top to bottom, and not frames. Different color lenses will make you to look modern and very stylish.
6) Rimles Aviators continue to be on the highest tops in fashionable eyewear world. This season they give us a sleek and modern look. They will look especially good with sport - style clothes.
What shape face do aviator sunglasses best suit?
It depends on the aviator type you mean, since you have two: 1. http://www.smartbuyglasses.com/designer-sunglasses/Ray-Ban/Ray-Ban-RB3026-Large-Metal-II-Aviator-L2846-16200.html 2.http://www.smartbuyglasses.com/designer-sunglasses/Ray-Ban/Ray-Ban-RB3250-Aviator-OO471-16213.html Both frames would look good on almost everybody, although you should be careful with long faces. In that case, the second frame might not look perfect. In addition, you should ensure that the frame color suits the hair and skin color; a golden frame might look very good on somebody with a tanned skin and black hair, while it would absolutely not suit somebody with a white skin and blonde hair.
Source(s):
Hi,Wondering if all you sunnies aficionados are able to provide me with a size comparison of the Ray ban Wayfarer 2132 medium (901-52mm) and large (901L- 55mm) , preferably being worn? I would like to get...
How do you unfold and fold a quinny buzz
Hi to unfold undo the clip if there is 1, some don't have them. lift the handle slightly then it should unfold it self.
To fold you need to apply the brake, stand in frnt then the 2 large grey buttons either side of seat, 1 pushes in 1 comes forward, do this & pull down towards your feet this will fold it up. Don't mistake the small grey buttons on side of seat they are to lay seat back/forwrsd etc; the large buttons are on the frame.
Oct 08, 2008 | Quinny Buzz Jogger
Ray-Ban RB 4105 Sunglasses Logo
1,757 people viewed this question
Top Ray-Ban Clothing Accessories Experts
Andrew Taylor
Andrew Taylor
legerdress
legerdress
How To Fix...
How To Fix...
Level 1 Expert
Are you a Ray-Ban Clothing Accessory Expert? Answer questions, earn points and help others
