Question about Ray-Ban RB 2030 Sunglasses
I need a replacement arm for rb2030 ps8 w2175
The left side arm is broken where can i get a replacement
Vince Dorman
    New Friend:
Perhaps try a retailer who carries this item. I found this site who carries them:
https://www.go-optic.com/rayban-sunglasses
Posted on Sep 10, 2018
ilhn
    New Friend:
I'm in need of Ray Ban PS8 W2175 right temple as well.
Could anyone help, please?
(Or the whole frame, just to use the lens in good condition)
i need a replacement arm for rb2030 ps8 w2175 - 2d67df0a-3a58-4e06-9ee1-cc3f77a4ba44.jpg
Posted on Apr 12, 2015
Christopher Deemer
    New Friend:
I'm sure I'm too late but just call Ray-Ban service at 1-800-343-5594. Follow the prompts and just stay on the line! You'll eventually get a person. I ordered a pair of "temples", as the rep referred to them, for $16.39 shipped to my door in 7-14 business days.
Posted on May 16, 2014
Lindsay Joye
    New Friend:
I need one replacement right arm. Wan to share an order since they only sell them in pairs? $54/pair at
Posted on Mar 23, 2014
I have a 2002 chevy impala,drivers side windshield works great,the passenger side doesn't work at all,help!
You mean wiper arm ? Probably broken wiper arm linkage bushing you can't see , under the cowling . Can you move the passenger wiper arm up an down without much effort ? An not the drivers side ? To see it or get at it you would need to pull wiper arms off an take cowling off to get at it . How To Install Replace Wiper Motor 2000 05 Chevy Monte Carlo Impala How To Fix Broken Wipers EricTheCarGuy
Feb 12, 2017 | Cars & Trucks
I replaced the ribbon cable on my Frigidaire refrigerator and the ice auger for the ice continue to run and water will not dispense when water dispenser is activated. I want to correctly replace the r
Hey friend, thank you for your inquiry!
From my understanding you were replacing the water dispenser on your Frigidaire refrigerator and the ribbon cable disconnected. I would suggest a generic search online for any additional information regarding the ribbon cable. I was unable to locate that information for you. Additionally, if you continue to have problems I would consult with a professional technician for proper attachment of the cable. Best of luck! -Matt
Sep 11, 2014 | Frigidaire Refrigerators
Left front lower control arm broken in 2004 Honda Civic Hybrid
i would replace it, not easily done you need special tools
Feb 13, 2014 | 1993 Chevrolet C1500
The driver side tire is sitting visibly farther back from the passenger side, it has a very hard left hand pull when brakes applied, but wheels turn freely in neutral when raised off ground. recently...
Check the control arm, and the control arm bushings on the left side. Sounds like something is broken, loose, or totally worn out. Use a sturdy pry bar to try to force it in different directions front and back, any play will become apparent.
Aug 21, 2011 | 1989 Cadillac Seville
The left arm-clamp has come off. It seems to be different from the left arm-clamp. At first I thought I just needed to figure out how to reset the spring, but a neighbor seems to think that the arm was...
They break. The latch arm is one piece, spring and all. So if any part of it is still in the
juicer it's broken. Order a pair from Omega and have them walk you through replacing
them.
Nov 22, 2010 | Omega 1000 Juice Extractor
Windshield wiper driver's side went limp wind
THe wind doesn't just push the power arm off, it must be broken and will need be replaced, You need to check if the actuall bracket that holds the arm is broken as well. It has teeth on it which when the arm is put on it lock in place with a clip
Feb 28, 2010 | 2004 Chevrolet Cavalier
The cable traction cable is broken on my toro personal pase lawn mower. part number 105-1844 how do i change it
I changed the cable on my toro mower but i cant make it go unless i pull back on the handle .i cant find a picture to see what i am doing wrongcan you help. Thanks
May 04, 2009 | Toro Lawn Mower With Toro Power Tools
Dirt left on dishes on top tray; bottom tray washes fine
The broken bottom arm is probably preventing any water / water under pressure to get to the upper arm.
After you replace the lower arm, you should have much better cleaning in the top shelf.
While you are in there replacing the lower arm, recommend you remove the filter under it and clean the filter and any debris you find. Be careful of broken glass!
Good Luck!
Apr 03, 2009 | Dishwashers
Broken water dispenser arm
I just fixed this today. 01/2/08
First, I got some super glue from Lowes especially designed for plastics.
I first glued some metal strips to the back or the broken off lever, so it will have extra support once glued back. I then applied glue to the broken surface of the lever arm and the support arms I glued earlier.
Super glue it awesome, just had to hold it in place for 1 minute, then let it cure for a few hours... working good as new.
I'm glad this worked for me, as I did not want to have to search for the part and then worry about taking the refrigerator apart.
After repair, I had to educate my wife on how to slam a cup into the arm HEHE.
Dec 10, 2008 | Frigidaire PLHS267ZA Side by Side...
ESTATE WASHER
ck lid switch earlier modes had switch on right of lid opening later it was moved to left rear hinge area ..those on right just replace those on left first ck hinge screws on left be sure they are secure listen for click when closing lid..no click raise lid push on hinge arm on left side toward rear of washer slightly try again still nothing remove console screws on rear of console lift and roll console back ck switch on left side may be broken if so replace
Sep 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Ray-Ban RB 2030 Sunglasses Logo
2,540 people viewed this question
Top Ray-Ban Clothing Accessories Experts
Andrew Taylor
Andrew Taylor
legerdress
legerdress
How To Fix...
How To Fix...
Level 1 Expert
Are you a Ray-Ban Clothing Accessory Expert? Answer questions, earn points and help others
