Question about Ray-Ban Ray Ban Aviator Sunglasses Metal Frame And Glass Lenses Unisex
How do you find out if Rayban Aviator are genuine or false? I have a couple of tips, but I wanted to know if there was some extra thing to check. Please do not tell me any obvious stuff like "go to the shop" I am a collector and I know all basic stuff already.
Jyackle5
  • 8,197 Answers
These are the markings to check for.
Older Models made by Baush and Loma.
-Ray Ban B&L Made in the USA across the top part of the upper bridge.
-Size Markings on the paddles. (Only if they were not changed out, and are not the wrap around ear frames)
-Ray Ban white logo on the Right eye Lens. (Left if you are looking at the glasses) this should not come off easily like, with a cleaning cloth.
-B&L etched in the lenses, many knockoffs will have it painted.
-B&L engraved in the nose guards
Further information needed
Newer Ray Ban's made by Luxottica
-All newer Ray Ban's sold in the U.S.A will be made in Italy.
-Ray Ban Made in Italy under the top bridge
-Made in Ray Ban made in Italy CE on the inside right leg.
-Correct size and model info on the left inside leg.
-R&B etched in the lenses.
-Ray-Ban painted white on the Right Lens (Again won't come off easily)
Applies to both
-Should not have a mix of the above features....common mistake (Example made in USA across the bridge and made in Italy on the leg.)
-If painted, it should be enamel and should not come off easily.
-Hinges should have a distinct shape, not oval, and should not have any "burn" marks on the metal from being fused.
-The paperwork..sometimes called care book. (not the registration card) should be crisp with a professional work. Common fakes are printed with regular or shiny paper, haphazardly folded, sometimes colors will be bleeding, and or the English is full of typos.
-Mispelled words on the protective case if it has one. This should also match with the glasses. Luxottica with Italy made and Baush and Loma with U.S.A.
-Box is beat up or has Asian characters.
-Hinges should move smoothly but should not be loose. (Older/Used may require tightening.)
-Plastic lenses. An easy way to test this is to direct the car A.C. air at the lenses. Glass lenses will cool rather easily will feel cooler to the touch than plastic.
-Have them checked at a local sunglasses place, UV can be tested too. Many cheap priced sunglasses misrepresent the amount of UV that is blocked. Ray Ban's have a good reputation of Blocking that 99-100%
Posted on Jan 22, 2011
  • Anonymous Jan 22, 2011
    I know all that stuff JY.
    That does not work. Good replicas have all that.
    What I need is the specific weights per series and sizes. There are also specific difference. For example replicas have BL and all the marks, but those do not match with the ones used in that year or in that product. There is more stuff like this.
    That is what I was looking for.
    Take care.
halliibo
    New Friend:
? have a ray ban 3386.but not writing made in italy right inside.is it pseudo??
Posted on Jun 12, 2011
What is the removal procedure for a/c compressor in 1994 Cadillac Seville 4.6
Alan, There could be a big difference from year and model and engine on changing A/C for a Caddy, . Re POST year, make, model, and complete question so we, here at fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Aug 23, 2016 | Cadillac Cars & Trucks
What is the difference between true pelvis and false pelvis?
Sandile, Check the attached links, lesser or greater pelvis.
False and True Pelves Boundless Open Textbook
Pelvic cavity Wikipedia the free encyclopedia
define true pelvis and false pelvis Google Search
false pelvis
Mar 14, 2016 | The Computers & Internet
How do I play?
This link will help you get the extras you seek, among other things. http://www.imore.com/bubble-witch-saga-top-10-tips-hints-and-cheats
Feb 09, 2015 | Facebook Apps
2005 Lincoln Aviator - Hazards and Signals don't work
On the Lincoln Aviator there's a set of fuses under the dash of the vehicle. One set has to be dropped to get to the flasher fuse.
Nov 28, 2011 | 2005 Lincoln Aviator
I took my 04 Lincoln Aviator through the car wash. Now the powered seats, mirrors wont work. I have only had the car for a couple of days. Can someone tell me what the problem might be? Chris
They are on the the same fuse and relay system. One or the other have gone out. Look in the owners manual and look under fuse and relay. It will list which fuses are what, and will also with the relays. It will also tell you where they are. check these first, and let me know if that's not it. Will help you more from there then. hope this helps
Jan 04, 2011 | 2004 Lincoln Aviator
What are G-15 XLT lenses on rayban sunglasses?
Asked the same question. This is the answer recevied from rayban customer service: "The B15 is a brown lens and the G15 is a grey/green lens. Both lenses allow 15% light through the lens. It also blocks the UV reds and UVB rays".
Nov 07, 2010 | Clothing Accessories
2005 lincoln aviator blinkers just stopped working. Replaced bulbs and checked fuses all are fine? Any thing else we are missing?
You will need to check the flasher, it is located under the dash just above the gas pedel, it is in a small black box with removable cover.
Let me know if you need further assistance.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 11, 2010 | 2004 Lincoln Aviator
Air conditioner blows hot air when it wants and cold air when it wants, wondering if anyone knows the name for the part I need to replace?
My advice is to take the car to a certified a/c specialist as there are several things that can cause your problem
Jul 17, 2009 | 2004 Lincoln Aviator
Don't know what dashboard diagnostic light means (03 Lincoln Avi)
there is a small button on the side by the shifter,with the engine running press that again and that light shoul disappear.
Jan 13, 2009 | 2003 Lincoln Aviator
Under 50,000 miles - 2004 Lincoln Aviator - replaced rear end - now quoted $3700.00 for new #6 cyclinder. There are problems with this car. Cyclinders do not go bad with this many miles on them. What the...
The problem is the Lincoln Aviator is a piece of junk!!!! If anyone is thinking about purchasing one turn around and run. I cant begin to tell you how many problems i'v had and continue to have w/my 04 Aviator. I know this aint much help I just don't want to see anyone else end up like us...
Aug 05, 2008 | 2007 Lincoln Aviator
Ray-Ban Ray Ban Aviator Sunglasses Metal Frame And Glass Lenses Unisex Logo
3,078 people viewed this question
Top Ray-Ban Clothing Accessories Experts
Andrew Taylor
Andrew Taylor
legerdress
legerdress
How To Fix...
How To Fix...
Level 1 Expert
Are you a Ray-Ban Clothing Accessory Expert? Answer questions, earn points and help others
