Schlage BE365-PLY  BE365PLY626 Satin Chrome Electronic Security Keypad Elect Logo
Posted on May 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to replace battery
Light on top (only) is flashing red. What does it mean? How do I replace the battery.
Anonymous
Level 3:
  • Master 963 Answers
  • Posted on May 19, 2012
Anonymous
Master
Level 3:
Answers
963
Questions
0
Helped
489469
Points
1500
Give these instructions a moment to load:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Red lights flashing roller not coming on
When the red light is flashing while connected to the charger means the battery is being charged, once fully charged the light turn from red to green without flashing. If the red light is flashing while being use means the battery is low and in need of charging.
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 • Drills
1helpful
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Battry charged but red light on gun still flashes on im 250
The red light flashing on the gun means that the battery does not have enough voltage to operate the tool. Try another battery and if it still flashes red you need to replace the spark unit
2helpful
It wont power on & has a red flashing light
2 things, first bad battery, sometimes bad battery works for few minutes then your phone just dies on you, it says its fully charged but it aint. That red light flashing only means that your phone has LOW BATTERY. 2nd your phone software has problem. If you have another ericsson that uses the same battery you can check it the battery is ok, its the only way you can find out if the battery is good. If the battery is doing ok with another cellphone then your cellphone software has problem.
4helpful
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
4helpful
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
7helpful
Flashing light
It depends on the mouse. Sometimes the red light flashes to signify the processing of a command. If it is continually flashing, then you may want to replace the battery.
7helpful
2answers
Flashing Red Light....
The flashing "boat" in the middle of the viewfinder just means the button battery is dead. Camera will still work. It's the little pull-out light grey plastic thing that's next to the heel of your right hand when you're using the camera normally. You need a CR2025 cell.
EX-Z75 Camera Battery won't charge. Red light flashing
Red light flashing means faulty battery. You need to call tech support and they will replace the battery for you. Just make sure you tell them that it's been under a year since you purchased it. :)
Top Schlage Locks & Locksmithing Experts
john h
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
