Question about Schlage BE365-PLY BE365PLY626 Satin Chrome Electronic Security Keypad Elect
When I press the Schlage button the door automatically unlocks. Why is that? just learned that all someone has to do is walk up and press Schlage and then theycan walk right in.
Posted by clayhite3 on
  • Cale Gray
    Cale Gray May 25, 2017
    the only thing that fixed this for me was drilling out more space so the deadbolt could completely extend when in locked position. my hole was a little shallow so it was only locking 3/4 and this caused it to unlock simply by pushing the schlage button. i drilled out the hole completely and as long as i completely extend deadbolt when locking im good to go.
Anonymous
    Sniper:
  • 68 Answers
You need to pull the cover off and you will find a 2 wire terminal that needs to be moved over one pin.
Posted on Mar 23, 2009
  • 2 more comments
  • Cale Gray
    didn't work
  • Jen Marie
    Jen Marie Jul 16, 2017
    I had the same problem. In the manual it says the Schlage comes enabled with the feature of hitting the Schlage pad and opening the door without a code. You have to disable it by punching in the programming code (not your user code) and wait for 3 orange beeps, then hit the Schlage and it will lite up, and then punch in 7 and it will be green with a long beep which tells you its now its disabled. Only difference is you will have to enter a code to lock as well as unlock, which is fine with me, as long as i don't have to leave it basically open. This is better then taking it apart all over again.
  • Anonymous Sep 07, 2017
    thanks for the post. This worked for me. :D
  • Alexander Arango
    Alexander Arango Apr 01, 2018
    It worked to perfection. Thanks for taking the time and answering the question.
Anonymous
    New Friend:
http://consumer.schlage.com/Service-Support/Pages/InstallationTroubleshooting.aspx#5 Why can my electronic keypad deadbolt (BE365) be unlocked without a four digit user code when I press the "Schlage" button?This is most likely due to an installation error. When the lock is assembled on the door, two steps of the installation must be followed to insure proper operation. The deadbolt must be installed in the door edge with the bolt retracted, and the gray plastic cam on the interior mounting plate, through which the flat metal driver bar passes, must be pointed down (see below). The gray plastic cam has a triangle embossed on the end opposite the driver bar which should align with a matching triangle on the orange plastic cover plate below. These instructions are also embossed on the orange plastic plate.
Troubleshooting Image 2
If the cam is improperly aligned, the lock must be disassembled to a point where, with the bolt retracted, the cam can be turned to the correct position without moving the bolt. This will require withdrawing the flat driver bar completely from the cam before turning the cam. The driver bar will then pass through the cam at a forty-five degree angle when the lock is reassembled.
Posted on Sep 16, 2010
  • apb290 Oct 07, 2010
    Thank you very much that helped kinda freaked me out that it did not catch this until a couple of weeks. The only big questions is why does this thing not automaticaly lock after you shut the door I thought they all did really wish I knew it did'nt I would have not bought this one.
  • Sylvester LeMeilleur
    Sylvester LeMeilleur Dec 26, 2018
    Thank you. The lock has to know when it is in the lock position via the cam switch or else it will not need a code to unlock it.
Carlos Morgado
    New Friend:
I get that this is a setting, why in the f**k would schlage even make this possible, just in case you want a front door that is totally useless?
Posted on Aug 03, 2016
3 Related Answers
Coaltowner
  • 963 Answers
SOURCE: door will unlock without entering code
"Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial? "
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Posted on Feb 22, 2012
Coaltowner
  • 963 Answers
SOURCE: schlage camelot key pad does
Here is a link to the installation instructions:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
It sounds like you may have the Turn Lock Feature disabled. View and scroll down in the instruction sheet to the Troubleshooting portion, where it says " Pressing (the) Schlage (button) does not rotate deadbolt" The solution is to push the PC button, then the Schlage button, then 7 to enable the turn lock feature.
Here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
http://consumer.schlage.com/Service-Support/Pages/ContactUs.aspx
Posted on May 06, 2011
Coaltowner
  • 963 Answers
SOURCE: I have a BE365 Lock on my door. When I go to lock
How do I enable the alternative setting (Code Turn)? (BE365 Deadbolt only)
1.) Enter your current 6-digit programming code
2.) Push the button
3.) Press 7 on your keypad
Posted on Nov 09, 2011
Keyless schlage lock opens when schlage button is pushed
  1. Remove the two screws on the back plate.
  2. Disconnect the battery
  3. Remove the two screws on the inside of the lock so that you can remove the entire lock.
  4. Once you have removed the lock from the door take the backplate in hand
  5. Right above the orange plastic piece there is a small black egg shaped cam.
  6. Turn the black egg shaped cam to the side and then turn it back down so that the arrow is pointing down.
  7. If you do this right the deadbolt will stay in the unlocked position. The deadbolt will not retract when you turn the cam because it should be completely disconnected
  8. Once you do this correctly you will reinstall the lock in the unlocked position.
This also will fix the light not coming on when you press the Schlage button.
Dec 15, 2017 | Schlage Locks & Locksmithing
Our schlage lock with thumbturn on inside and keyed on outside. When unlock inside, knob turns freely as if it is really unlocked but if I close door, I get locked out. Please help
Be sure the outside knob is unlocked before closing the door.
Schlage locks do not lock the inside knob or lever. After releasing the turn button, also turn the inside lever or knob, then check the outside knob.
What model of lock is this?
Apr 09, 2014 | Locks & Locksmithing
How to change baterry o schlage be365
To change the battery on the BE365, you need to remove the inside cover by removing the two screws (one above and one below the deadbolt knob). Be careful to tuck the wires inside the lock so that they will not be crimped when you put the cover back on.
Do you here a beep and see a flashing light? Usually if pressing the Schlage button unlocks the deadbolt, your installation was done improperly. The cam on the base plate must be vertical and the bolt must be correctly installed.
You will always be able to lock and unlock the deadbolt with the inside thumb knob.
I hope this helps.
Dec 04, 2013 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Shlage keypad dead bolt unlocks when you press the
Videos for installing and programming can be found on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Aug 31, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
Door will unlock without entering code
Feb 15, 2012 | Schlage BE365-PLY BE365PLY626 Satin...
Just bought a 2004 hyundai Santa Fe. Trying to learn how to set the alarm. Can someone help me please?
PRESS THE REMOTE TRANSMITTER UNLOCK BUTTON ONE TIME DEACTIVATES ALARM AND UNLOCKS THE DRIVERS DOOR ONLY. PRESSING THE REMOTE TRANSMITTER TWICE DEACTIVATES ALARM AND UNLOCKS ALL DOORS.
Feb 01, 2011 | 2004 Hyundai Santa Fe
I have a BE365 Lock on my door. When I go to lock the door it wants the code punched in and the knob turned. When i unlock it, it just wants the schlage button pushed and knob turned. HELP
2.) Push the button
Nov 16, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
How do i change the code on my keypad outside the garage door on my chamberlain whisper drive? someone stole the sticker from the pad... thanks
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Nov 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
I press the schlage button i can unlock the door by turning the button
Complete installation & programming instructions can be found here:
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Scroll down and find them under the heading Electronic Security... 365
Good luck--and please provide feedback if this helps!
Nov 06, 2010 | Schlage BE365-CAM BE365CAM619 Satin...
DOMINO KEYPAD PROGRAM NEW CODE. LOST INSTRUCTIONS
Press and immediately release the smart/learn button on your motor unit and then walk over and put any 4 digit code you like and press enter.
Jul 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Schlage BE365-PLY  BE365PLY626 Satin Chrome Electronic Security Keypad Elect Logo
15,427 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
Mike
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
