Garden Logo
Edward Posted on Mar 31, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Starter will not operate
Put jumper cable directly from battery to starter. Starter still would not engage. What am I doing wrong?
  • 4 more comments
  • Edward Apr 02, 2012
    Hello Mike, I installed a new Solenoid & starter. According to what I read, connecting a jumper cable directly from the battery to the starter, should activate the starter. Nothing from the starter. I disconnected all wires from the starter & bypassed the solenoid.
  • Anonymous Apr 02, 2012
    try and jump it from a car your battery maybe to weak if your bypassing the solenoid
  • Edward Apr 03, 2012
    Battery was OK. But tried another. Same thing. Nothing!!! Sparks came off the new battery when touching the + post. Suspect a short, but it's a brand new starter.
    I'd like to know exactly how to get the starter to engage , if it's good.
  • Anonymous Apr 03, 2012
    what brand and size engine do you have?
  • Edward Apr 04, 2012
    17.5 HP Briggs & Stratton. Will call them today.
  • Edward Apr 06, 2012
    This one really had me going, but figured it out with your help. Battery was reading 12 volts everywhere, but when turning on the ignition, voltage dropped to 8-9. So I tried your suggestion of another battery, & what do you know!!! It started. It was the battery all along. Thanks for all the help.
Anonymous
Level 3:
Brigadier General:
  • Master 6,468 Answers
  • Posted on Apr 02, 2012
Anonymous
Master
Level 3:
Brigadier General:
Answers
6468
Questions
0
Helped
2134371
Points
13357
Is the starter drive gear kicking in does the starter have a solenoid on the starter then you need to power that as well that kicks the drive in
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Nov 11, 2008
SOURCE: Husqvarna LT2042
the soneloid switch sends power to starter . check power on red wire on starter when key on full .if no power must be soneloid switch problem even though it clicks
Phil Rivera
  • 83 Answers
  • Posted on Mar 30, 2009
SOURCE: Starter will not engage. All safety switches are
Here is the manual. It includes a troubleshooting chart and the location of the fuses. Give it a shot and if it does not work out contact me again.
http://manuals.deere.com/cceomview/OMM142612_D7/Output/Index.html#25348
Anonymous
  • 81 Answers
  • Posted on Jun 20, 2009
SOURCE: Starter flywheel is not engaging motor
If you blew a fuse you could have a grounded wire someplace. Check the wiring on the solinoid, on the battery, on the lights and anyplace there could have been a bear spot rubbed. If the flywheel does not engage check the flywheel gear on the end of the started to see if it is chewed and worn. These can be replaced easily,
nova2nv
Bill Linda Rivard
  • 197 Answers
  • Posted on May 29, 2010
SOURCE: John Deere 316 the starter doesn't engage often.
You need to instal a starter relay kit.Deere part # AM107421.Mount it down by the starter,purple wire that goes to starter will now be plugged in to the relay,red wire to hot side of starter,black wire to a ground point,purple wire that is a part of new relay can now be plugged in to the starter.its very easy to install and fixes nearly 100% of clicking starter.
Anonymous
  • 1627 Answers
  • Posted on May 31, 2010
SOURCE: riding mower-starter relay clicks-no start even with jumpers.
The frame of the tractor is the same thing that starter grounds to,so yes ,put the ground any where on the frame or engine block to test the starter.An easier way to test everything is to cross over the large posts on the solenoid with a screwdriver and if it turns then the starter is not the problem.Then you will need to put power from the post on the solenoid that has the battery positive connected to it ,to the post on the solenoid that should come live with the key,if it starts then then you likely need an ignition switch if not you need the solenoid.
Testimonial: "thankyou for your expert help, I feel a lot more confident now about the problem.will run the system checks you described. thanks again, grump."
2answers
93 C1500 4.3 POSITIVE CABLE AND BODY GROUND CABLE MELTED. I REPLACED BOTH BUT I DONT HAVE ANY POWER ANYTHING ON THE FEWS ARE GOOD. WHERE DO I LOOK.
Did you replace the battery as well? If both cables are badly melted it is likely the battery has suffered damage as well. Do you have access to a Multimeter? Set it to Volts DC. With the engine OFF put the red pin to the red positive battery terminal and the black pin to the black negative terminal. If the battery is good you should get a reading of around 12.6 volts or higher. Anything below 9 volts and the battery is probably worn out or damaged.
You will also need to find out what caused the cables to melt. There is most likely a 'Resistance' issue somewhere in the electrics. This is where the voltage is restricted and cannot flow correctly. This generates heat and is possibly the reason the cables melted. Have you 'Jump Started' the vehicle recently? Connecting jumper cables the wrong way around can have a similar effect.
How to check starter system on a John Deere 2355 tractor
Weak battery / Loose or corroded cable to battery or starter . If you can get to starter posts with jumper cable try to jump it if it trurns
over the starter is not the problem. Check all connections as a first step this sounds like a bad connection or weak battery.
Aug 18, 2014 • Garden
I have a 50 hp outboard mariner when i turn the key the starter does not engage
Could be many things.flat battery,faulty batt cables,dirty batt connections,faulty starter solenoid,worn starter brushes.suggest using jumper cables direct to starter to check if starter is ok.short circuit solenoid to see if that is not faulty.could also be broken wire in loom
Replaced battery and will not make a sound
Troubleshoot as follows: 1. Using a set of jumper cables connect the Black side of the jumper cable between to the (-) of battery and a the block of the engine. Connect one (red) end of the jumper cable to the (+) of battery...And just touch the other end of the red cable to where to mower battery cable touches the starter. *Only tap it and starter should turn over. This bypasses all switches and wiring. If it does not turn the starter, the starter is likely bad. If it does turn over, check the starter solenoid, seat safety switch, blade engagement safety switch, clutch brake switch, or wiring in between those components. A wiring diagram would be most helpful. It came with the mower, or can be found online...likely at a sears/craftsman web site, but sometimes also at parts retailer website too. Similar bypass method can be used for troubleshooting. DO NOT OPERATE WITH BYPASSED SAFETY SWITCHES, ETC. Bypassing is for troubleshooting only.
2helpful
2answers
Suziki Boulevard C90 wont start, when hitting the ignition nothing happens, but the lights dim
Your starter button is a two position switch. The lights are supposed to go dim when the button is pushed halfway in. When pushed in all the way it should activate the starter solenoid. The starter solenoid is located under the seat next to the battery. You can follow the positive battery cable directly to the starter solenoid. If you push the starter button and the starter solenoid clicks, then the starter button is good. If the you unplug the two smaller wires going to the starter solenoid and connect a voltage meter to the main harness leads , the needle should jump whenever you press the starter button. If it does not clean the button contacts or replace the right switch assembly. If the starter button is good then take a jumper wire and short across the two battery cables on the starter solenoid. This will put power directly to the the starter. If the starter works now replace the starter solenoid. If your starter still does not work, try holding the starter button and tapping on the starter with a plastic hammer. If the starter works now then you probably need to replace the starter brushes. If anything else is wrong with the starter you will need to replace the assembly as the dealer will usually only offer the starter brushes for repair purpose.
2helpful
2answers
It started out just clicking when u pushed the starter button an now it dont do nothing ive got a new battery in it can you tell me whats wrong its a 660 grizzly 2004
get some wire that's equal in size or larger gauge than the battery cable (a jump start cable works great) and connect from one side of the solenoid to the other momentarily. The starter should engage. If it doesn't, you have either a dead battery, bad battery cable, or the starter relay is bad. You can also try a jumper from from the battery positive terminal to the starter side of the solenoid. If it engages then the the battery cable from the battery to the solenoid is bad. To test the relay, put 12 volts dc on the trigger side and the relay contacts should close. You'll hear them close with a click.
My 1998 Jimmy won't start. Just got a new starter. My battery is drain, when i use the jumper cables it still won't turn over.
with a new starter, this sounds like a bad battery cable or terminal end. the easier way to figure this out w/out checking the voltage drop across a whole battery cable is to affix the jumper cables strategically to find the bad one. Put jumper (+) on batt (+) and jumper (-) directly onto a piece of unpainted engine metal and not in the way of moving parts. If it starts this way then you've got a bad ground cable. If it didn't start, put jumper (+) on the hot post of the starter solenoid (there are 2 posts, only touch the one w/ the fatter cable going to it) or on a remote jump point if equipped, and put jumper (-) to batt (-). If it now starts you need a positive battery cable, or just a battery-to-starter cable (if separate)
2answers
1990 ford bronco2 starter
If the flywheel teeth are ok, it must not be engaging w/ the flywheel as u say. If u pull the starter out u can check w/ jumper cables, ground to starter body (flange for good clamping) and touch positive where pos. battery cable attaches, gear should travel to end of shaft and spin to engage flywheel, if it's not advancing to end of shaft, u need to return it for another rebuilt unit. Note, only touch positive cable briefly, the gear should engage w/great force, so be careful.
Top Garden Experts
Jay Finke
Jay Finke
john h
