SOURCE: missing or corrupt hal.dll file, so can't boot the hard drive
Hey,
Please use the recovery discs or windows installation cd.
To either perform a full system restore with the recovery discs.
Or to perform a repair installation with the windows installation cd.
Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
Press Enter to start the Windows Setup. do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
Accept the License Agreement and Windows will search for existing Windows installations.
Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup.
Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Thanks and good luck.
Ekse
SOURCE: missing RtlGina2.dll
The problem lies within your windows operating system registry, because the default MSGINA.DLL is replaced by a 3rd party GINA (Graphical Identification and Authentication) DLL which is the RtGina2.dll. This is due to improper installation of some programs or devices, maybe you or anyone else using your pc improperly deleted, removed, uninstalled or installed programs on your pc, that's why this error comes out.
Possible Solution/s:
You need to reset the registry to use the standard windows GINA DLL file to set Windows XP back to its defaut value of MSGINA.DLL. In order to do this, you need to download xp_fixlogon to your pc, download this file to your hard drive and run it to reset the registry and fix this issue. After running the file, restart your pc.
http://www.onlinepcrepair.vox.com
http://www.onlinepcrepair.url-go.com
SOURCE: where can i download yimage.dll for free to open
good day,,
just reinstall yahoo messenger.
go to http://messenger.yahoo.com
or send me your email address and ill send you the file
Yeah sure, format the whole world and all your problems would be solved. Sí claro, formatea tu compu y solucionarás cualquier problema. What kind of Master (Expert) do you think you are.
