20 Most Recent
Dell Latitude C840 Notebook Questions & Answers
NEED HELP TROUBLESHOOTING "NTLDR is missing" error message
You are looking in the right direction but your best option here is a restore to factory defult. Do you know the procedure for your particular laptop, if not then have a look at the Dell website. Do you have cd or dvd restore disks?
I often get laptops in with similar problems and first step is to take hard drive out and do backup of the docs then restore. I also have a WinXP live Hirens boot cd to boot up with and test everything.
How to remove Dell C840 password . the service tag is BV4Q421-595B
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :-
http://www.hirensbootcd.net/ http://67.20.82.163/
Www.teanviewer.com
first,, get into your bios pages on my netbook its F2 whilst booting but yours might be different.Then get to know pages,navigate with the tab key or use arrows play around with the pages but dont change anything untill your sure you know what your doing--then when you are ready save changes and exit,,here you can remove bios password or reset to factory settings--good luck,,davey
Chkdsk shows "one or more unrecoverable problems". Now what do I do?
You should run chkdsk /r which is the repair and it will repair the problems. Once you reboot and if you still have problems:Insert your Windows XP Home Operating System in the CD drive and boot from it. When the screen comes up showing you the options Select to INSTALL WINDOWS. After you hit F8 to accept the license agreement, windows will go and search your drive to see if there is a version of windows already installed. When it finds your Xp Home already installed SELECT THE OPTION TO REPAIR. This will cause all your data, documents, music, pictures, videos and programs to be saved and not removed. You won't lose anything.
My cousin gave me his
Yes, it is normal for this model. 1hr 15min is usually the normal duration that the model of this type of battery lasts. This highest it might go is 1hr 30mins. It's usually difficult for laptop of these kinds to stay 2hrs or more using battery.
There is no solution to this. You have no choice than to continue using it that way.
You are even lucky because some don't even last up to 1hr.
I hope I have answered your question.
Yours sincerely.
Elect_Comp.
BIOS password for Dell latitude
BIOS password is user initiated. To be straight forward with you and for you not to have false hope, there is no way we can obtain nor reset the BIOS password not unles we know what it is. Now, the solution to this issue is to replace the computer's motherboard.
Thank you for choosing FixYa!
What is extend ram capacity
There are a lot of reasons your laptop is not accepting the new memmories
1) If it is an old laptop the motherboard might not support upto 1 GB of memmory
2) It can also be due to the fact that the connections are loose and the ram is not properly inserted or dust is interfering the contact
3)It can also be due to the difference in frequency and latency of the new ram you inserted
4)it can also happen when the frequency of the ram exceeds the frequency supported by the Front Side Bus(FSB)re it is compatible and also ensure that it is properly fixed
Check the ram ratings and make su
