Turn it off before you burn your hose down. Nothing should be so hot as to make a sizzling sound! There shouldn't be any water on the outside of the unit. It sounds like there is leak.
If this unit has been in operation for a while, like a couple years and longer -- the coil that is under the unit is most likely completely matted up with dust. This needs to be cleaned. With the unit off use a vacuum cleaner, brushes -- any way you can devise to get rid of all the accumulated dust.
Because I can not think of what water could be dripping on to make a sizzling sound - or where that water be coming from - I'm going to suggest you call in a professional on this one.
There shouldn't be any condensate that can drip on anything. The clogged up coils underneath could cause the freezer not to cool properly.
A burnt smell sounds like electrical - and that's why I'm concerned.
Don
SOURCE: Bottom of freezer has water dripping into it
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
We had a similar problem. It ended up being a frozen pea that fell down into the defrost drain and was blocking the water from draining out each time the freezer defrosted.
SOURCE: refrigerator not getting cold enough
IF THE COMPRESSOR IS RUNNING ALL THE TIME IT CAN ONLY BE THE FREEZER IS NOT MAKING TEMP.OR YOU HAVE A AIR LEAK SOMEWHERE ON THE DOOR GASKETS OR WATER ICE DISPENSER,LET ME KNOW-MIKE
SOURCE: freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
SOURCE: maytag fridge water dripping from inside freezer side
This sounds like the evaporator drain may be clogged either in the freexer compartment or at the outlet to the drain pan under the unit. Every defrost cycle the defrost element makes water by melting the ice on the evaporator coils. If the drain is clogged there is no other place for the ice to go. Many times the drain may just have ice buildup in the evaporator drain funnel that can be corrected with a manual defrosting.
To do this manual defrosting all you do is first unplug the unit then remove everything from the freezer compartment. After that place a fan blowing into the freezer section for a little over 2 hours. Please NOTE this will make more of that pesky water mess so be ready to tend to the mess as it presents itself.
After the 2 hour fan session plug the unit back in and reload the freezer compartment with previous content. Monitor for the possibility of the water manifeting itself again.
In addidtion to the above there is a drain pan catch basin in the bottom of the unit near the compressor. They are usually white plastic on Maytag units and not to rugged. Make sure that the drain pan is not loaded with debris. There is about a 1/2 inch diameter opaque plastic line that drains into the catch basin. That is the Evaporator darin tube. Ensure the very end of the tube does not have caked up debris in the very end of the tube. Sometimes this tube cakes up and then the debris dries hard inside the tube near the end. Make sure the tube is free of foreign objects and clean.
After all of the above / cleaning and clearing / manual defrosting it is still making water then most likely the lower panel under the defrosting element / evaporator may have become disconnected allowing defrost cycle water from the melted ice into the freezer compartment vs exit via the drain. To fix the disconnected power metal panel problem the rear freezer panel would have to removed to re-attach / repair the metal panel that guides the water into the evaporator drain.
Thanks for using FixYa.
Kelly
The sizzling in your case means that it is working....it is just water dripping from the cooling coil onto the hot element that defrosts it...
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
