SOURCE: BOSE 321
Have u tryed other disc ? if so your Bose system my have read a corrupted disc u may want to change out your IDE cable and if that doesn't work then corrupted files has made its way to one of your main broads.
SOURCE: I put in a dvd and i get format not supported?bose 321 gsx system
-If this happens on all DVDs, then this may need to be repaired (Bose will repair this for free if this is the case- they can test it too)
-If this happens on some or most DVDs, you can try a firmware update. Call Bose at 800-367-4008 and tell them about this. Request the most recent software/firmware update disc.
If you haven't already, just try resetting this first. (unplug the power cord from the acoustimass module for about 30+ seconds and try again)
If this happens primarily on rentals or home-made dvds, an update will most likely fix the problem.
