Used the top oven to roast mushrooms a couple of weeks ago. Steam poured out of the oven and the analog clock display showed moisture under the glass. None of those controls have worked since. Called Viking and after being shunted to 5 different service centers was told to turn off the circuit breaker to reset. Didn't work. I have had the ovens for 14 months - used them no more than 10-12 times (thanksgiving, xmas, bake a birthday cake). Out of warranty and Viking will not honor. I am sad and mad! Any advice? BTW no moisture showing now but obviously no seal or seal broken.
SOURCE: viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
SOURCE: my viking electronic oven display blank
Contact Viking. I am pretty sure that the display unit still has a parts warranty.
SOURCE: I have electric double oven VEDO275SS by Viking
you need to have a new thermostat fitted or the old one re callibrated if possible
SOURCE: Viking double ovens. Can both ovens be cleaned at
Unplug your oven, and clean both at once., Yes, you can.
SOURCE: the digital and analog timer do not work
No, there is not a fuse on this model. You will need to repalce the clock assembly for this unit. Call us asap and we'll ship the correct part out to you asap so you can start cooking again. We look forward to working with you!
