20 Most Recent Viking 27" Professional Select Built-in Electric Single Wall Oven Questions & Answers
The door to my viking oven is locked and stuck,
Must be taken out of wall far enough to remove top panel and manually disengage lock
9/30/2018 11:41:08 PM • Viking 27"... • Answered on Sep 30, 2018
7answers
Viking oven - very loud vent fan noise, run 30 min. after 'off'
That is probably a defective control board, give me the model number.
4/14/2018 9:22:02 PM • Viking 27"... • Answered on Apr 14, 2018
Viking oven buzzes all the time when not in use
the low voltage transformer on the ERC control is vibrating from not doing anything,when you put a load on this transformer it will quit,only fix is to possibly remove ERC and jam a piece of NON-Flammable/NON-electrical metal to keep it from vibrating and try this first,if this doesn't help,replace the noisy board with this transformer on it
1/13/2013 1:30:25 AM • Viking 27"... • Answered on Jan 13, 2013
After I turned my oven off, it sounded like it was
Most of the kitchen appliances with electronic control have cool down cycle, this takes place after you turn the unit off, cooling fans for controls will continue to run to cool down the control to a safe temperature (around 160 to 200F, depending on the design).
It is very important not to disconnect the unit from power source during cool down cycle to prevent damage on electronic components or controls due to over heating.
Regards.
6/10/2011 5:08:23 AM • Viking 27"... • Answered on Jun 10, 2011
0answers
0answers
My Viking oven will not lite, the igniter glows,
That sounds like you have too high of gas pressure which keeps the oven gas valve from opening...turning on the burners lowers the gas pressure enough to allow the gas valve to open. this is a saftey feature on many gas valves.
To stop that you will need to install a gas pressure regulator which will hold back the gas pressure so the valve can open.
Here is a tip that I wrote about regulators and them failing on the low side, but it will give you and idea what I am talking about and what you need to install in the line to your range.
http://www.fixya.com/support/r5849793-propane_lp_or_natural_gas_regulator
heatman101
4/22/2011 4:22:34 PM • Viking 27"... • Answered on Apr 22, 2011
The stem/shaft that holds the oven knob seems to
first pull the knob off the shaft and check to see if its broken where the shaft is supposed to lock-in if so u jus need a new knob. if not you have to pull the panel off the stove and replace the shaft this shouldnt be too difficult either way.
1/24/2011 3:43:20 PM • Viking 27"... • Answered on Jan 24, 2011
Viking 27" Electric Oven Noise
Hello. The Viking does have fans which operate continuously to insure even baking. If it sounds like fans running, this is the convection fan operating. J.
7/1/2010 2:12:13 AM • Viking 27"... • Answered on Jul 01, 2010
Have a viking professional oven and it takes too
A weak oven ignitor will cause this problem. even though it eventually lights the temp has dropped considerably so you don't get consistent temp. turn the oven on and listen for the burner to light. should light within about 2 minutes. if not replace oven ignitor(s)
5/20/2010 4:01:54 AM • Viking 27"... • Answered on May 20, 2010
Oven will not light.
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
4/5/2010 4:24:04 AM • Viking 27"... • Answered on Apr 05, 2010
Viking oven VESO107CSS, tried to start cleaning mode, it would not start. Now the oven will not heat and the cleaning light is flashing
If your Viking oven VESO107CSS will not heat and the cleaning light is flashing, it's possible that the oven control board is experiencing a fault or malfunction. Here are some steps you can take to troubleshoot the issue:
  1. Turn off the power to the oven: Before attempting any repairs or troubleshooting, make sure the power to the oven is turned off at the circuit breaker.
  2. Check the door lock: If the oven door is not properly locked, the cleaning cycle will not start. Check to make sure the door is securely locked.
  3. Check the oven control board: The control board may be experiencing a fault or malfunction. Try resetting the control board by turning off the power to the oven for a few minutes, and then turning it back on. If this does not work, the control board may need to be replaced.
  4. Check the thermal fuse: The thermal fuse is a safety device that protects the oven from overheating. If the fuse is blown, the oven will not heat. Use a multimeter to check the continuity of the fuse, and replace it if necessary.
  5. Check the heating element: If the heating element is damaged or burnt out, the oven will not heat. Use a multimeter to check the continuity of the element, and replace it if necessary.
If none of these steps solve the issue, it's recommended to contact a qualified technician or the manufacturer's customer support for further assistance.
2/25/2023 6:46:12 PM • Viking Ovens • Answered on Feb 25, 2023
Where can II get a replacement 11 in by 16 in oven bake element with 9 inch contacts for my eaton viking model 305 vin
There are several options for obtaining a replacement oven bake element for your 11-inch by 16-inch Eaton Viking 305 Wine model with 9-inch contacts. Here are some of the options you can try:
Check if the manufacturer Eaton Viking offers a replacement element compatible with your oven model. You can check their website or contact their customer service for help.
Look online for spare parts stores for appliances. You can search online or local stores that sell oven bakeware for your oven model. Some popular online stores include Amazon, eBay, or appliance parts sites.
Contact an oven technician or servicer for assistance. A qualified technician may be able to help you find the correct replacement oven bake element for your Eaton Viking 305 Wine model.
Look for online forums or groups for appliance owners. There are online groups where homeowners discuss their experiences repairing and maintaining their appliances. You can join these groups and ask questions for help and advice on finding a replacement oven bake element for your Eaton Viking 305 Wine model.
It is important to note that you may need to provide the exact model number of your Eaton Viking oven when searching for a replacement part to ensure you get the correct part for your appliance.
2/15/2023 4:56:54 AM • Viking Ovens • Answered on Feb 15, 2023
Viking 27" Professional Select Built-in Electric Single Wall Oven Logo
Popular Tags
24 questions posted
Top Viking Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Viking Oven Expert? Answer questions, earn points and help others
View Most Popular
Viking Ovens
  • Viking Ovens
Most Popular Question
viking oven very loud vent fan noise
  • Ovens
