you can resolve EPSON STYLUS CX3200 How to place 2 detached springs and a black plastic piece ·L-shaped in the cleaning area of the print head error by connecting Epson printer customer support number 1-800-213-8289. We assure you that we will givw you the best services.
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
You don't need a shifter assembly. Inside your console is a small "pink" plastic lever that has a spring attached that locks the shifter in park. The small "pink" plastic piece where the spring is attached breaks off. Mine broke off at 45000 miles. Billet technologies makes a aluminum replacement for about $60.00 that won't wear out. The Chrysler forum has pictures and detailed instructions on the replacement procedure.
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
I had the same problem with mine, it's due to the fact that the smaller spring has become un-lodged from the ******** itself.
You will need:
1. Roll of electrical tape.
2. Utility Knife
3. A small slot head screw driver OR a pair of needle nose pliers.
The solution is to unscrew the silver ring so that is can be moved up
and down. Now, you need to use a utility knife and cut the blue rubber
off of the spring. Once you have the blue rubber but off you can see a
large spring with another smaller spring inside. Push the head of the
******** till the larger spring's coils are an 1/8 to 1/4 of an inch
apart. Next take either the small slot head screw driver or a pair of
needle nose and jam the smaller spring back into the hole in the center
of the white plastic piece inside of the larger ring. Next plug it in
to make sure the vibration is working, reattach the silver piece and
tape the larger spring with electric tape.
ONE OF THE ARTICLES IN, www.fixya.com/support/t262916-printer_carriage ,GAVE US SOME GOOD INFORMATION. IT REFERS TO A PAGE IN A PARTS MANUAL THAT WAS IN PDF FORM, WHICH WE HAD TROUBLE DOWN LOADING. WITH THE DOWN LOADING OF AN UP DATED ADOBE, WE MANAGED TO VIEW IT. THE ASSEMBLY THAT THE WHITE PLASTIC L SHAPED PIECE WAS MOUNTED TO WAS HANGING DOWN, AND HAD COME LOOSE. THE PLASTIC L PART GOES ON ONE OF THE SHAFTS ON THE LITTLE WHITE PLASTIC CARRIER, THAT MOUNTS INTO THE SLOTS. NOTE THEIR IS A SMALL SPRING THAT IS ON ONE SIDE AND IT ATTACHS TO ONE OF THE SHAFTS ON THAT SIDE OF THE WHITE PLASTIC CARRIER. PUT IT BACK TO GETHER IF THE PARTS AREN'T BROKEN AND THE PRINTER SHOULD WORK. I FEEL IT WAS THE SPRING COMING OFF OF THAT SHAFT THAT ALLOWED IT TO COME LOOSE, AND SHUT THINGS DOWN. GOOD LUCK
I think you may have the skills to make it get some plastic epoxy or , i get them from a auto parts store but you can also find them in home improvement stores, etc
make a small paper cylindrical mold that would engulf the old plastic piece, fill it with epoxy to the top, turn it upside down and place it on the plastic part where the old hook was. once solid you can cut this to size so it will hold the spring.
Well it turned out that that 45 degree plastic piece DID or WAS attached to the main post. It snapped off. I super glued it back on and to each side of that very flimzy broken plastic I cut two very small pieces of wood (using popsicle sticks) and super glued THOSE to either side of the broken armature piece. Once dried I re-attached the spring and it worksd like a charm.
