You probably don't need to replace the hard drive. It may very well have enough space to install Windows 7. You can likely install Windows 7 on the old PC, but depending on how much ram the machine has it may not be such a great experience in the end.......seriously. If you can get 1 gig or more of ram in it, then it may be feasable to install win7, but don't expect much in the way of performance. I don't mean to sound negative though....if you're so inclined, then go for it! It is probably do-able.
Joe
SOURCE: I have a Toshiaba laptop which had a hard drive
You can install the windows to follow this step.
Make sure that the CD drive is on first boot. When you turn on your laptop you need to press the delete key fast, to access the BIOS. Once you have change the BIOS settings you need to save it. After you save once the laptop detecting the windows CD press the enter key fast also to boot from CD.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
