20 Most Recent Western Digital Caviar SE WD800JD SATA Hard Drive Questions & Answers
Just install it. No jumpers are needed on a SATA drive.
Western Digital... | Answered on Aug 16, 2017
No jumper is necessary for a SATA drive. Just install it and the PC will assign a drive letter to it.
You can add the drive as an additional drive just by setting the drive jumper to slave with master installed and it will give you another drive letter. https://eshop.macsales.com/Tech/manuals/idehdsettings/WD72.pdf
16383 is usually the number.
The case must be designed for SATA drives. Once the drive is installed in the case, use a USB cable to connect it to the computer. Connect the power supply to the case and start the computer. There will be a new drive letter present.
Hello Joe,
Please visit the link provided below :
http://wdc.custhelp.com/app/answers/detail/a_id/981/p/288,95/c/123/session/L3RpbWUvMTMxMzU4ODkxOS9zaWQvN1JOSzdNQms%3D
Western Digital... | Answered on Aug 17, 2011
There are pins on the Sata drive that have to be set. The good part is that there is a diagram on the device that will tell you which settings are for Master/Primary and Slave. You want to set it up as a Slave.
Sometime the connection ribbon from *********** board will have master/slave written on them. These also need to be correct depending on the computer.
Western Digital... | Answered on Jun 28, 2011
The noise is probably a repeatative clunk sound. If so then afraid its no good and you will need to buy a new one. I have been using WDD hard drives for years and they are the best. If you enter the bios you will most probably see that it is detected. The clunk is the head hitting the platter. Any data on the drive will not be readable. Srri
Western Digital... | Answered on May 31, 2011
Open My Computer icon on the desktop. locate the hard disk you wish to format in FAT32. Make sure is not your main drive where windows was installed which is Drive C: Right click on the drive you want to format and select Format, a formatting window will pop out, there you see capacity which is the size of your hard drive,File system, and so on. Select the drop down menu under File system where we have NTFS and FAT32. Set it to FAT32. Under Format Options, Select Quick format and click Start. A warning message will pop out Click Ok to proceed. Wait a moment until the formatting is complete. Good luck.
Western Digital... | Answered on Feb 03, 2011
There should be jumpers on the back of both hard drives. You need to set the primary hard drive jumper to MASTER and the secondary hard drive jumper to SLAVE. Here is a picture of the jumper settings.
I hope this helps you.
Western Digital... | Answered on Jan 29, 2011
If you are trying to use the drive in a windows XP system you will need a driver due to the fact its a SATA drive (very few are supported by Win XP) .
You should be able to find a Windows XP driver on the Western Digital website.
At the start of the Windows XP install process you will be asked to press F6 to load SATA drivers.
If my memory serves me right you will need to have the driver on a floppy disk to install them.
This should sort your problem.
Western Digital... | Answered on Jan 16, 2011
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Western Digital... | Answered on Dec 31, 2010
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
go to control panel administrive tools computer management you can right click on the drive select properties tools check now?tick in both boxes to scan for and attempt to repair/recover any bad sectors and automaticall fix any corrupt files
in xp
hope this helps
If you are going to make an online purchase, you should purchase directly from Western Digital's E-commerce web-site. This will assure that you will have a "warranty" that has good value.
Note that Western Digital has a "Customer Loyalty" program -- if you are the owner of any Western Digital disk-drive, you should qualify for a discount on your online purchase of a new disk-drive, if purchased through their web-site.
Western Digital... | Answered on Dec 16, 2010
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
hope this helps
Western Digital... | Answered on Dec 10, 2010
depends entirely how they are connected. you have posted this under SATA har drive, sata hard drives do not require any kind of jumpers.
Western Digital... | Answered on Dec 06, 2010
Western Digital Caviar SE WD800JD SATA Hard Drive Logo
36 questions posted
Top Western Digital Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Marvin
Marvin
efs_perpends
efs_perpends
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Caviar Western Digital
  • Caviar Western Digital
Most Popular Question
hardrive in
  • Computers & Internet
