Question about Western Digital Caviar WD2500BB 250 GB Hard Drive
Want to remove wd2500 drive from HDD enclosure and
I dropped my external Hard disk Drive and now want to remove the wd2500 drive from HDD enclosure and install it inside my PC. The drive works but the external plug on the enclosure housing is damaged. I have removed the drive and want to simply install the drive in my pc. How do I do this?Are there cables I need?
Posted by lanedt on
  • lanedt Dec 08, 2009
    I believe it is ATA?? There is one long socket on the drive with 39 pins in 2 rows, another socket with 10 pins in 2 rows and a power socket with 4 pins.
    Thanks for any help you can give.
    Lane
  • Chris Hingee
    Chris Hingee May 11, 2010
    What type of data connection has the hard drive got? Is it ATA/IDE or SATA?
Chris Hingee
  • 32,281 Answers
OK your hard drive is an ATA drive.
You motherboard will have two hard disk controllers, on the 1st controller the ATA cable will have two connectors - a connector will have the C drive hard disk attached to it and the jumper on the hard drive will be set as the Master drive. You may also have a CD or DVD drive connected to this cable, if so then the CD or DVD drive will be jumpered as a Slave drive.
If the second connector does not have a drive connected, then you can connect the second hard drive to this connector BUT it needs to be jumpered as a Slave drive.
You may elect to connect the second hard drive to the second IDE controller instead on the first controller. If there aren't any drives on the second ATA cable then the second hard drive can be jumpered as either a Master or Slave drive.
If there is a drive on the second ATA cable you need to determine the jumper setting of that drive and then set the jumper on the second hard drive to a different setting. BOTH drives on the same cable CANNOT have the same drive setting.
After installing the second hard drive, check the BIOS configuration of the second hard drive, if the hard drive is detected then when Windows boots up you will see the hard drive and its contents.
Posted on Dec 08, 2009
ikkenom
    Brigadier General:
  • 10,406 Answers
Take a look at the connectors at one end of the drive. Compare to the picture at:
http://www.madshrimps.be/articles/MaxtorULTRA16300GB7200SATA-Liquid3D-7741.jpg
for two similar "SATA" drives.
The drive on the left of the picture has two groupings of pins.
The smaller group receives electrical power from your computer,
and the larger group sends/receives "data" signals from your computer.
The drive on the right has an additional "Molex" 4-pin connector on its left side -- just a different way of receiving electrical power.
It's possible that your drive may have a 40-pin (2-by-20) "data" interface.
So, either way, you need to get power from your power-supply to the disk-drive, and you need either a "SATA" data-cable or an 40-pin (or preferably 80-pin) "IDE" data-cable between your motherboard and your disk-drive.
Hi! i have an external hard disc Toshiba PX1396E-3T01. i've connected the divice to my pc but the red light doesn't turn blue but instead keeps on blinking blue. what's wrong?
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 23, 2010 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
SAMSUNG 40GB HARD DISK MOTOR IS NOT ROTATING AND SYSTEM SHUTDOWN IMMEDIATELY WHEN IT IS CONNECTED TO PC
* the USB cable
* the power-adapter
Nov 10, 2010 | Samsung 80GB INTERNAL 3.5- IN SATA HDD...
I have 500GB Roco (Toshiba) external hard drive... It was not dropped or physically damaged. My desktop and my laptop don't recognized it anymore. What seems to be the problem and how can i fix...
* the USB cable
* the power-adapter
Nov 10, 2010 | Toshiba 120GB USB 2.0 Portable External...
My seagate external hdd 500gb is not working and is not detected and regonised in any pc..
* the USB cable
* the power-adapter
Nov 07, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My usb external Buffalo ministation is not been recognised on my pc and the LED light is flashing green and orange
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 04, 2010 | Buffalo Technology 320GB MINISTATION TURBO...
I have a iomega eGo HDD and its not showing up on my computer but it shows up under my devices how do I fix that
It depends. If this is the _very_ first time that you have connected the IOMEGA device to your computer, you'll need to "initialize" the HDD for usage by Windows (or Mac OS).
Or, if you've previously done that, and you've written files onto it, and now cannot read those files, you have an entirely-different problem, namely a "hardware" problem.
An external storage device has several major components:
* the USB cable (which in your case, seems OK, since the device is listed)
* optionally, an external power-supply that connects to the enclosure.
Use a multi-meter to measure the voltage/amperage generated by that power-supply,
and compare with the specifications on the power-supply's label.
Disassemble the enclosure, and remove the disk-drive.
Connect it as a "slave" disk-drive in a desktop computer, to see if bypassing that USB-to-disk-drive adapter bypasses the problem.
If the device is still under warranty, IOMEGA will replace it, at minimal cost to you.
If the warranty has terminated, buy a new, compatible, disk-drive, and install it inside the enclosure, to "revive" your external storage device.
Nov 04, 2010 | Iomega Computers & Internet
Hard disk not detected
Try plugging the enclosure's usb to another USB slot. If the computer still will not read it, then the enclosure itself might be defective and not the actual harddisk that is inside.
To verify this, try to mount the harddisk to another enclosure and test. If the enclosure is still under warranty, you can return it back to save repair costs.
Aug 17, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
Dead processor. good hard drive
get external hard drive shell, place the hard drive in it, the connect via firewire or usb all your info should be intact except if its a crash
Mar 23, 2010 | IBM ThinkCentre A50 PC Desktop
Hard drive failure in system less than 2 years old!!
Since you are comfortable with working inside your computer, the best thing to do now is to purchase an external enclosure for your type of hard drive, SATA or EIDE.
Alternately you can use a live linux cd, boot up with that, and transfer your data to an external drive.
Once your data is safe, try booting to the Windows cd and attempt a repair installation.
And finally, yes, hard drives can go bad in 2 years or less.
Dec 14, 2008 | Dell Dimension 2400 PC Desktop
PC won't recognize external usb HDD
You may not have installed the HDD correctly in the case... I had the same problem with my Thecus N1050 enclosure, the green power light on the enclosure would come on and the drive would spin up but my PC would not see the HDD!!??... I thought, becuase i could hear the drive spinning that i had it installed correctly but this wasn't the case, when i removed the enclosure again and FIRMLY pushed the HDD into the connector (all the way in) and connected it back up to my PC, it recognised it instantly. Hope this helps!
Jul 25, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Western Digital Caviar WD2500BB 250 GB Hard Drive Logo
4,757 people viewed this question
Top Western Digital Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Marvin
Marvin
efs_perpends
efs_perpends
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
