Question about Western Digital WD Caviar Blue WD3200AAJS - hard drive - 320 GB - SATA-300 SATA
I need firmware for Western Digital WD Caviar Blue WD3200AAJS - hard drive - 320 GB - SATA-300 SATA
Posted by Vlada on
Brian Sullivan
  • Western Digital Master
  • 27,725 Answers
If you are troubleshooting a system or OS problem, you should not consider firmware updates until after exploring more typical troubleshooting steps like file system error checking and anti-virus scanning.
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this should schedule the task on restart then defragment your hard drive
http://download.cnet.com/western-digital-disk-manager/3000-2122_4-10008018.html
This file contains the most up-to-date Disk Manager drivers for Windows 95 and Windows NT 3.5.1. This file fixes numerous issues, especially those with IBM PS/1 Value Point machines. These drivers will replace Ddloader.bin and Xbios.ovl files that were installed with previous versions of Disk Manager.
hope this helps you
Posted on Oct 20, 2011
My computer doesn't recognize my hooked in to 3.0 USB port on my ASUS laptop, initialized, SATA 2TG internal drive that's within an external case.
depends on the operating system but normally if you can see the drive in pc manager (right click mycomputer icon, select manage, select disk management in windows) if the drive is listed then format it and allow automatic drive letter assingment
Mar 20, 2014 | Western Digital WD Caviar Blue WD3200AAJS...
WD 3200AAJS jumper settings for slave
Sata drives have no jumper settings. The computer will find it when you install it.
Mar 03, 2013 | Western Digital WD Caviar Blue WD3200AAJS...
How to slave a WD3200AAJS Hard Drive
Sata drives require no jumper settings. Just install it and the computer will do the rest.
What jumpers are for slave Western Digital WD Caviar Blue WD3200AAJS - hard drive - 320 GB - SATA-300 SATA
SATA drives don't need jumpers. Just install the drive and the computer will assign a drive letter.
Jun 06, 2012 | Western Digital WD Caviar Blue WD3200AAJS...
Wd3200 aajs external drive light flashes and won't come on.
Get a new case and transfer the hard drive to the new case. You can get cases at any store that sells computer parts and several places online.
https://www.walmart.com/c/kp/external-hard-drive-enclosures
Sep 25, 2011 | Western Digital WD Caviar Blue WD3200AAJS...
Hi i bought WD 320 gb sata /8mb hard drive - the cable ribbon on my dell 4600 does not plug into it! do i need a different cable yes
Generally speaking, we have two types of hard disk interface. IDE (the old one with ribbon cable) and SATA (with a 1cm strip like cable).
As your new hard disk is SATA, you need a SATA cable to connect it to you PC.
Below are a few images which would help you.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 23, 2011 | Western Digital WD Caviar Blue WD3200AAJS...
Computer will not recognize hard drive
Make sure that in the computers bios, the SATA port is enabled, and that all the cables are properly connected, if the drive is brand new it needs to be first Partitioned and then formatted for it to show up in your "my computer" or computer folder.
Sep 01, 2011 | Western Digital WD Caviar Blue WD3200AAJS...
Western Digital WD Caviar Blue WD3200AAJS - hard drive - 320 GB - SATA-300 SATA Logo
4,025 people viewed this question
Top Western Digital Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Jeffrey Groves
Jeffrey Groves
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
