You need to check the input selection on your tv on screen menu. Some AV in settings will pick up part of a signal but not all. Make sure you try all input selections. To prove that the problem is not in the AV lead.....try connecting it on another small tv with a known working DVD/TV combination.
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the surround system, connect either an optical audio cable or red & white analog audio cables from the tv to the home theater. If you are using optical audio, there is a plug on back of tv labeled for digital audio output and an input on the surround sound system. If you plan on using analog red and white, use the PROG OUT red and white output jacks on the back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or Component cables. HDMI is the cable that will provided 1080p signal (the best HD signal), but if the source does not output 1080p, then your tv will not display 1080p. Most cable boxes output at 1080i or 720p when on HD stations. This signal still provides great picture quality, but HDMI is not needed to get these HD signals. You can use component cables for your cable box and the DVD player output to the tv for video. HDMI might give you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the tv (component or hdmi). Also from the home theater system to the tv using hdmi or the video cables from component (red, blue, & green cables).
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
it sounds like a loose connection with your signal but if the connection is tight i have seen loose connectors on the small signal board itself which may be resolveable by resoldering connector on signal board which would be far less expensive than replacing signal board itself
