SOURCE: Polaroid FLM-3232 Blue Screen 'No Signal'
yeah stay away from polaroid! In the meantime check this out.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
SOURCE: HDTV picture staticky, cuts out
I suggest contacting Sharp directly. I just did and received absolutely nothing from them. But if others such as myself who have the exact same problem as you ( I own a LC32D40U just over 2 yrs old) contact then maybe something can get done.
I will certainly NEVER recommend a Sharp product to anyone and will as of this moment respond to every message out there letting everyone know exactly how bad Sharp's product are. I would recommend the Sony XBR series to anyone looking for an LCD television.
SOURCE: RCA HDTV, indoor antenna and Dish Receiver 311
I want to use two (2) 311 dish receivers with only 1 outside antenna.
SOURCE: displays weak or no signal
To get any HDTV to work this is what you have to do;
CHANNEL section
1) Connect your antenna cable which you have done.
2) Go into the menu to the source option and select AIR/ANTENNA since you are using an antenna.
3) In the menu you will have to SCAN in the stations. This auto program will find all available stations.
Now you can watch tv by selecting the station you want.
The new generation of HDTV is different from the old analog sets. These have to be set up to work.
Exact information can be found in your Users Manual.
