OKI C8800dn Led Printer Logo
Anonymous Posted on Sep 08, 2017
Our OKI C8000 has recently started having printing quality issues. Very streaky. Thin white vertical lines appearing on all colours. Image drums not showing as spent. I have tried cleaning the heads but no better. I'm happy to replace something but not sure what causes this issue in all colours and don't want to unnecessarily change all the drums. Any suggestions?
4 Related Answers
A
Anonymous
  • Posted on Jul 11, 2008
SOURCE: poor print quality
your heads are defective due to a mumber of reasons. cheaper to buy new one
Anonymous
  • 113 Answers
  • Posted on Jul 08, 2009
SOURCE: poor print quality- streaky lines across the page
The problem might be with the type of paper you are using. Some printers require different paper types. Check the manufacturers website to see what kind of paper you need.
Anonymous
  • 22 Answers
  • Posted on Jul 24, 2009
SOURCE: Print quality problems C3400n
And the problem is with the magenta drum.
Testimonial: "You answer was 'spot on'!"
xptareq2000
Tareq Bin Mostaq Mostaq
  • 1449 Answers
  • Posted on Aug 13, 2009
SOURCE: Very poor black print quality and an almost full
yes you change it and buy new one because toner brush is not supply toner properly
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
C5800 printing vertical lines through pictures
The thin lines are caused by a worn out drum. Remove each drum in turn and look at the surface. It maybe hard to see the scratches and if so then send solid blocks of the primary colours one at a time and that will prove which drum is at fault.
1helpful
Okidata C5200N printer: streaky copies on magenta
If the streaks are only from the magenta then your magenta drum is bad. If you recently replaced it, it may still be under warranty.
I have a Oki C9500 laser, the magenta print is streaky
I have the same problem with my OKI c3100, please help
2answers
We have recently bought a second hand OKI C5200 Colour Laser Printer and even though the black and white print seems to be great the clour is coming out with coloured streaks, what would you recommend?
One or more of the drums may be defective. Swap the black with another color and print a document. If that color printed the charectors ok, then continue the test with the other drums each taking a turn in the Black drum position until you find the bad drum.
4helpful
2answers
1helpful
Oki C3100 - v poor print quality
Hi Errol
The way to identifiy your problem is to send a full colour print to your printer and open the top just as the paper starts to come out . if you then remove your toner / drums for all the colours you can see the transfer belt if the quality of the image that you can see on the transfer belt is good and clear your problem is with the transfer form the tranferbelt to the paper and not any toner /drum issue and the most likley cause is the transfer belt itself "but before you relpace it remove it and clean around the electrical contact points and generally make sure the internals of the printer is free of loose toner .
Regards Alan (Alstech)
1helpful
Poor quality print
Try cleaning the LED heads. These are located in the lid and are facing you when you have raised the lid. A quick wipe with a dry cloth or tissue should help. If in doubt, check the user manual.
2answers
Oki C3400 colour printer
It has been recommended this is a toner/image drum problem. I am to replace the image drum, toner and check the print out.
Top OKI Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
