Hello
As there is no "Meny" button on the front panel of your tV, it is not possible to select its inputs. Just buy one orginal remote control of this device, or buy a unversal remote control which has setup codes for your Sansui combo. Some universal remote codes for Sansui combos are 0394 0967 & 0310. Just look for a suitable universal remote control, which ahs setup codes with your Combo. you will get these details from the broshure of the remote control. OK.
I did buy an original remote and it does not work either..What to do?
Check the remote sensor. It is inside the TV.
You have to open your TV to access this part. It can be located just behind the remote sensor window at the front panel of the TV. Will be a three terminal component, look brownish black in color, diretly soldered to a printed circuit board. This won't cost more, and can be bought from most of the electronic sparepart selling shops at your town. It will have a typical number printed on it and should be noted when buying a new one.
The work is somewhat skilled one, and if you have knoledge in electronics, and have tools to do the work, you can do it by yourself at home. OK.
