20 Most Recent
Sansui HDLCD3250 32 in. LCD TV Questions & Answers
How to reset sansui to factory settings
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Cover Removal
This is not the same model Sansui, but it is a tv.
http://youtu.be/qMpiC8YL3SE
What is the format to play a video in a usb mode
Hi! I'm a little confused about what you are asking. Do you want to watch a movie from a USB flash drive or connect a USB device (DVD player, etc) to your tV? Please give a little more detail and I;d be happy to help.
Iwant reseting tv
If you want to make a hard reset, just unplug the TV from AC wall outlet, and re-plug it back after 20 minutes of so. If you wish to make a system reset, you have to enter its service mode to do this.
If you wish to get more details, check the site linked here
Selecting the view option, either to
Mosaic / Time
slide, can be selected by the
drop-down list, at the top left of the
display window, will make surf easy.
You can also do a search, by type in the brand name/model number/IC
used, in the search box at the top right of the display window.
Stand lcd
Contact the autthorized dealer for Sansui.
My Sansui tv went to a black screen and has no sound
Try these steps to fix the issue with your Sansui TV:
- Check connections and source
- Ensure TV is on and power cord plugged in
- Reset the TV by unplugging it and plugging it back in
- Verify audio settings and that speakers are on
- Contact manufacturer for further assistance if needed.
How do I hook up a VCRDVD player to my sansui flat screen TV and what do I need to do in terms of channels or inputs or setup to get this accomplished
To connect a VCR/DVD player to a Sansui flat screen TV, you will need to use the appropriate cables and connections. Here are the general steps you can follow:
- Check your TV and VCR/DVD player for the available ports. The TV should have RCA composite video and audio inputs, and the VCR/DVD player should have RCA composite video and audio outputs, or HDMI port.
- Using the appropriate cables, connect the RCA composite video and audio outputs from the VCR/DVD player to the corresponding RCA composite video and audio inputs on the TV. If your VCR/DVD player has HDMI port, use HDMI cable to connect the TV and the VCR/DVD player.
- Turn on your TV and VCR/DVD player.
- On your TV, press the "Input" or "Source" button to switch to the input where the RCA composite video and audio cables are connected or HDMI.
- Using the remote of your TV, go to the menu and select the input where the VCR/DVD is connected.
- If you don't see any picture, try adjusting the settings on your TV and VCR/DVD player.
- Once you are able to see the picture on your TV, you should be able to use your VCR/DVD player as you normally would.
Sansui LCD TVcode for sansui LCD TV
The codes for a universal remote to work with a Sansui television are:
Sansui television remote code 834
Sansui television remote code 0310
Sansui television remote code 0394
Sansui television remote code 20695
