SOURCE: dial clicks round
Open the rear panel and look for a broken or worn belt. If this is the problem you can replace it easily. Good luck !
SOURCE: Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
SOURCE: Ariston washer dial starts turning and won't stop -no wash/spin..
CHECK THE PIPE TO THE DRAIN HOSE AND FILTER TRAP IF ONE FITTED IF BLOCKED CAN CAUSE THE SAME THING ESPECALY IF YOU HAVE A NON RETURN VALVE FITTED
SOURCE: Ariston A1635 Margherita Control knob spinning
According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
SOURCE: Arison AW122 -frontload washer-- On off light goes
There is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
