Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Error Code: 51330
This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
If you are still receiving this error code, please click here for assistance.
But
if the above information doesn't help correct this problem, then give a
call to Nintendo's 1-800-255-3700 (6 am ~ 7 pm Pacific, everyday)
Customer Service number, and one of the service representatives will do
some over the phone troubleshooting to determine exactly what is causing
this and then talk you through any needed steps to correct it.
But
Unable to connect to your wireless network
Likely cause: It appears that the security settings entered into the Wii console are not the same as what your wireless router is set to allow.
How to fix: Make sure the security key and security type are entered into the Wii exactly as they appear in your router's settings.
Additional information:
Other suggestions:
