SOURCE: DEH-P750MP Setting Time Pioneer
hey... i hope this it worth a 100% vote lol.. Premier CD PlayersHow do I set the clock on my single CD player? For most Pioneer single CD players, you can set the clock using the following steps: Press and hold the SOURCE button until the unit shuts off. Press and hold SOURCE again until the clock appears. With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button. Press the left or right arrow to select the segment of time you wish to adjust. Press the up or down arrows to increase or decrease the numbers in the blinking segment. Once the clock is set correctly, press the SOURCE button to exit.
SOURCE: how do you make an aux port work on Pioneer
turn off the unit. after it powers down hold the function key and a menu pops up. from there just hit the function key untill you find aux and then turn it on.
SOURCE: AUX input on Pioneer DEH P31000
There is a plug on the back called an IP-BUS. You should be able to hook the ipod directly up to that with a simple homemade adapter. I built one for mine and it works fine.
http://stereophonik.com/gutterslide/IP-BUS_Hack/
SOURCE: I need the wiring diagram for the Pioneer CD
Red= acc 12v
Yellow = constand 12v
black = ground
blue/white = remote turn 12v out.
purple pairs are the Right rear speaker
Grey pairs are the front right speaker
white pairs are the front left speaker
green pairs are the left rear speaker
orange white is the dimmer.
