Schlage BE365-CAM  BE365CAM505 Lifetime Polished Brass Electronic Security K Logo
Posted on Aug 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do erase a code and add a new one? - Schlage BE365-CAM BE365CAM505 Lifetime Polished Brass Electronic Security K
Anonymous
Level 3:
  • Master 963 Answers
  • Posted on Aug 26, 2011
Anonymous
Master
Level 3:
Answers
963
Questions
0
Helped
489464
Points
1500
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This number is the programming code referenced in the information for changing the entry code.
This link will take you to the page that you need to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Deadbolt BE365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
How to reset DIC on eldorado cadallic
Hook up a scan tool to the computer. Erase codes. Autozone will not erase codes for you but they will read them. However if you push the button yourself they dont care. They just dont want to be held responsible.
How To Pull Codes DTC
Does disconnecting the battery wipe out the diagnostic codes
no, disconnecting the battery will not erase the trouble codes. in fact it will add a new code indicating the battery was disconnected
2answers
I replaces brakes and needed to add fluid to master cylinder, when i did i pulled off a small hose that went to air regulater and check engine lite came on. i found where hose went and put it back on but...
One can try to disconnect the battery to erase the code, but on later model cars, one needs an OBD-II scanner to erase codes (from 1996 on up).
On older OBD-I type cars disconnecting the battery for 30 sec. used to erase codes.
1helpful
I erased firefox toolbar
Please follow the following steps:
1) Open Your Firefox Browser.
2) Select "Customize" from the Toolbars Menu.
3) Add New Toolbar.
4) Name the New Toolbar.
5) Add Items to New Toolbar.
6) Add Items to New Toolbar.
7) Show Icons and/or Text.
8) Click Done.
I pod touch while sincing new data, old is getting erased
Hi, I think you are using Itunes to Sync your IPOD-T.
If u r using Itunes Then u shouldn't delete any thing from ur ITUNES... Because, Sync is a option which will check the contents of your ipod and Itunes... If u erase anything from your itunes, then it will erase the same in ur IPod as well.... So U shouldn't delete anything from ur itunes....
Other option would be Manual Sync option... Where u have to drag and drop the contents from ur Itunes. Everytime....
Let me know, whether u want to manually add contents to ur ipod. so tat i can send u the settings?
When everything was erased, i wasn't able to add new games.
well what has happened is where you have turned it off it has somehow affected the action replay so get a new one ok
3helpful
2answers
Changing the combination
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You must have the factory combination in order to change the combination that was added to the safe and the factory combination can not be erased if that is the combination you are trying to erase.
All you have to do is press program & type in the factory code 2 times & that will erase the number you created.
Then to add a new combination all you have to do is: press program followed by 5 new numbers. Then to see if they new number works, just type in the new combination & the green light should come on & you have 4 seconds to turn the handle
Top Schlage Locks & Locksmithing Experts
john h
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
