Master
- Posted on Aug 24, 2011
Re: Lexmark t614 manual feed how it works
- Push the lower release latch. The multipurpose feeder door drops open.
- Pull out the metal bar in the recessed area on the multipurpose feeder, far
enough to accommodate the paper you will be using.
- Slide the paper width guide to the far right.
- Prepare the print material for loading:
- Flex paper or fan envelopes back and forth. Do not fold or crease the paper.
Straighten the edges on a level surface.
- Hold transparencies by the edges and avoid touching the print side.
- Fan the stack of transparencies to prevent jams.
- Be careful not to scratch or leave fingerprints on the
transparencies.
- Use the stack height limiter as a guide for stack height when loading print
materials.
- Load one type of print material in the multipurpose feeder. Do not mix
types.
- Slide the paper width guide over until it fits snugly against the side of
the print material.
If you need further assistance please contact Lexmark Technical Support.
