20 Most Recent Lexmark Optra M412 Laser Printer Questions & Answers
The Mirror Motor of the printhead is unable to reach operating speed. This means you have to replace the printhead.
Lexmark Optra... | Answered on Jun 20, 2016
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
You can find the fuser at the back of the printer, remove the cover and there it is. It holds in two screws and a power connection. If the printer is out of warranty, your next option is to change the fuser which costs around $200, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Lexmark Optra... | Answered on Mar 09, 2011
Go to Menu, then Paper Menu. Select Paper Source then select Manual Feeder. You should also select manual feeder from the driver.
I'd like to add the link to download the User's Guide for future reference. http://www.lexmark.com/publications/pdfs/optram410/enUser.pdf. Hope this helps. Leave a comment if you need more assistance. Thanks.
Lexmark Optra... | Answered on Jun 29, 2010
NO THE LAMP IS BAD
Lexmark Optra... | Answered on May 13, 2010
Sometimes the squeaks come from the drum inside the cartridge. If you remove the cartridge and power on and don't hear the squeaks, it's in the cartridge and not the printer...
Lexmark Optra... | Answered on Sep 15, 2009
Have you printed out the printer's Menu Settings?
Lexmark Optra... | Answered on Jun 30, 2009
error 939 means --
RIP Communications Lost
Controller EngineCommunications Lost
The controller board and the engine board cannot
communicate with one another.
Solution --
POR several times
Check each board
for secure ground.
Replace the assys
in the following
order
1. Controller Bd
2. Engine Board
3. Intterconnect
  Board
Lexmark Optra... | Answered on Mar 09, 2009
select the proper tray from the properties of printer. the properties could get by right clicking on printer icon.
Lexmark Optra... | Answered on Dec 27, 2008
That is not an error message. it is telling you to load the Manual Paper feeder. Put some papaer in it and it will print. check youyr set up to make sure that you are printing to the trays not the manual feeder
Lexmark Optra... | Answered on Nov 20, 2008
There is a sensor that detects paper just after the paper tray. No matter what is the reason that paper doesn't reach the sensor your printer will indicate that there is "no paper".
You should check is something preventing transport system even to reach the level of paper. In the case of Lexmark E342 or E250 printers, for example, two wheels with black rubbers rotating around common axis are pushing the paper . When you pull out the paper tray the transport system with rollers can be seen from the bottom side of the printer. If the rollers are not laying on the surface of the paper they can not push it inside the printer.
If you are sure that it is not the case the next thing you should check is the rubbers mentioned above. They must be clean enough to have efficient traction with paper. You should take the rubbers off the wheels, wash them with water and soap, rinse them and thoroughly dry. Put them back and try.
Lexmark Optra... | Answered on May 14, 2014
Lexmark United States Methods for Identifying the IP Address ...
support.lexmark.com > ...
This article provides instructions for obtaining the IP address of the printer. Several methods are outlined as not all printer models offer the same possibilities for ...
Lexmark Office... | Answered on Dec 08, 2019
hello sir,
dont worry this is d simplest case when either cartirage is choked or fileed with duplicate ink.
Try with another and if u still face this prob den reply
abhinav
Lexmark Office... | Answered on Nov 26, 2019
You can get best lexmark printer support at Toll Free Number ( 1-877-769-0969 ). Lexmark Printer Tech Support number ( 1-877-769-0969 )
Lexmark Office... | Answered on Nov 12, 2019
FixYa Experts: Once you have reached a certain number of answers, then you can Edit and Delete these spam posts too, so they don't victimize unwary users. By my estimate, 4 of your fellow volunteer Experts are currently deleting 5000 or more spams per day, and it's not keeping up with the flood. Please help us out.
Lexmark Office... | Answered on Nov 09, 2019
Lexmark Optra M412 Laser Printer Logo
19 questions posted
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Optra Lexmark
  • Optra Lexmark
Most Popular Question
921 service fuser error
  • Office Equipment & Supplies
