Televison & Video Logo
Posted on Aug 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The Polaroid TV/DVD/VCR COMBO TBX-2000AF that I have has this message appearing on the screen (while watching) no cassette loaded load cassette. How do I get this to go away?Thank you.Dawn
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Aug 15, 2011
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957623
Points
33084
Press Display key repeatedly to turn Off on-screen display or put a VHS tape in and leave it there to avoid that Display on screen.
Vhs tape is stuck and message reads "tape
Unplug the TV/VCR/DVD Combo from the main power for a couple of minutes, the unit may eject the tape at the power ON.
You can also try openening the unit, reset the loading posts and eject the tape by manually turning gears, motors etc..You have to know what you're doing otherwise, you will do more damage or get injured and don't forget HIGH VOLTAGE CAN KILL.
Best of lock
www.aaatvservice.com
Dvd does not load message says loading. then nothing happens .
Hello
Check with an other new disc. Check it with other disc that was running smoothly before. It that disc aslo not reads well, make sure that either its Laser assembly Lens is dirty, or the laser assembly itsef has damaged. Check it with an audio CD and MP3. If these work well and only it does nor reads DVD only, the fault is with lased assembly itsef. Put a head cleaning disc in to it and play it for two times. If this helps you, the lased head unit was dirty. If this also does not helps you, the Laser Pickup Assemby is defective and should be replaced with identical in both number and type. OK.
It is in the dvd mode. How do I get it to return to tv
Use the remote, look carefully and find the source/input button.
Red error message pops up while watching tv
Sounds like you OTR is on OTR on time record go into your menu of your TV and turn off the OTR feature you should be all set.
Thanks I hope this was Very Helpful for you!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
How can I fix the SLEEP function? My remote control doesn't work, the set shuts itself off after 15 minutes. TBX-2000AF the remote control is KDTR3
Unplug the TV from the wall, leave unplugged for a day or two, the TV may reset itself. You will lose all the programmed channels and may be other stored settings. The best is to get a universal remote for $10 or less.
Good luck
N Sabre
1helpful
2helpful
3answers
Remote code
I NEED OTHER REMOTE CONTROL AT POLAROID TBX-2000AF 20 IN TV/VCR/DVD COMBO. THANK YOU
2answers
Lock out
Press the power button on your rmote for about 8 seconds. This will "unlock" the child lock. To relock, do the same thing.
2answers
Remote control
don't have a solution to this problem .. am looking for one!!
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
